Question about Logitech QuickCam Fusion Webcam
Hi. My QuickCam Fusion has worked wonderfully until this past week when I used Skype to communicate with my son using the quickcam. The light was on, indicating it was working, but my son could only see a still picture of me. In other words, there was no active video being transmitted. Do you have any suggestions? The webcam to accidentally fall off the monitor to the floor about a month ago, but it landed in a pile of cords which broke its fall so I didn't think it was damaged. I hope you can help. I'm not good at all with troubleshooting. I checked the Installation Manual that came with the webcam and it didn't have any troubleshooting section. I hope to hear from you soon. Thanks.
    President:
  • 8,637 Answers
First check the camera and see if the button on the camera is stuck in the on position from the fall.
If no, do this,
Normal 0 Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Hope this helps. Bud
Posted on Feb 01, 2009
Hi, i tried using skype with logitech quickcam but pup-up told me this message: Another application (communications helper.exe) tries to access Skype but we are not able to respond. Try to restart the...
The easiest thing to try is just disabling "Communication_Helper.exe" in Skype. Go to Skype / Tools / Options / Advanced, and at the bottom you will see text that says "manage other programs' access to Skype". Click that and you'll get a window, which should list "Communication_Helper.exe". Deny access to that (don't remove it, because it will just come back), and try your call again.
Be aware, however, that this is only a quick fix and does not solve the problem. When Logitech and Skype have problems like this, they can be pretty big ones, and can cause performance problems as well as interface problems.
The Logitech QuickCam application software is not required for the Logitech Camera to function properly in Skype. If you are not using the QuickCam application for anything else, then you should seriously consider uninstalling it.
That will solve this problem, and various other potential problems and performance issues, permanently.
To uninstall it just go to Control Panel / Add or Remove Software (or Uninstall a Program in Vista/7), find "Logitech QuickCam" (NOT Logitech Camera drivers), and uninstall.
Then reboot to get rid of the background processes, and test Skype again.
May 05, 2011 | Logitech QuickCam Connect Webcam
My logitech webcam won't work in msn messenger....in messenger when i try to make a video call...it says I need to buy or install a webcam? what's the deal? heeeelp
Hi Marilyn,
Have you installed the Logitech Quickcam program? If you did then open the application and select the instant messenger(i.e. MSN, SKype, Yahoo) that you will be using the camera.
If you have note yet installed the Logitech Quickcam application then I suggest you disconnect the webcam and run the software first.
Oct 28, 2010 | Logitech QuickCam Communicate STX Personal...
Hi, i have just recieved my logitech quickcam im from a relative, and was wondering how to use it for my laptop. My relative told me that they had only used it once and place all items in box after use. I...
You need the driver disc and software, if you dont have them, download them from logitech. Install the software and drivers, plug the cam in, and away you go. most programs like skype and messenger should picj the cam up once the drivers are in.
Sep 04, 2010 | Logitech Quickcam IM 961361-0403 Webcam
Can't see the other person on skype
It's the others person's camera that is possibly configured wrong and they need to make sure that it works correctly. Good luck
Apr 28, 2010 | Logitech QuickCam Communicate STX Personal...
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub.
Mar 09, 2010 | Logitech Webcam
I can't get the video to work on skype. The solution said to add
If you have problems when you use your Logitech device in Skype, you may have to configure the audio and video setting in Skype. To do this, follow these steps:
  1. Start Skype.
  2. On the Tools menu, click Options.
  3. In the navigation pane of the Skype Options window, click Audio Settings.
  4. Select your Logitech device as the default microphone. (if it has a built-in mic) For example, select Logitech Communicate STX.
  5. In the navigation pane of the Skype Options window, click Video Settings.
  6. Select your Logitech device as the default Webcam. For example, select. Logitech Communicate STX
  7. Click Save.
  8. Test Logitech by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
Aug 29, 2009 | Logitech QuickCam Communicate STX Webcam
Hi, i would like to take live picturs and/or video while i am chating with skype and dont know how to do it. will you help me ? thanks, eddie
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Skype issues with your QuickCam Communicate STX trnsp.gif Detailed Description 1754.1.0.jpg This article explains what to do if you have problems using Skype with your QuickCam Communicate STX.
Model Number: V-UBK45
trnsp.gif Answer If you are experiencing difficulties using the QuickCam Communicate STX with Skype, check the following:
Verify the QuickCam Communicate STX is functional:
  1. Launch QuickCam software (Start > Programs > Logitech > Logitech QuickCam)
  2. Verify that you can see yourself in the QuickCam window as shown below:
  3. Close the QuickCam window.
Verify that the QuickCam Communicate STX is selected in the Skype Settings:
  1. Launch Skype (Start > Programs > Skype > Skype)
  2. Click Options from the Tools menu as shown below:
  3. Select the Video Settings option from the Skype sidebar as shown below:
  4. Check the Enable Skype Video checkbox as shown below:
  5. Check the "Start my video automatically when I am in a call" checkbox as shown below:
  6. Verify that your QuickCam Communicate STX is selected from the Camera drop-down menu as shown below:
  7. Verify that your QuickCam Communicate STX is selected from the Microphone drop-down menu as shown below:
  8. Verify that the "Let Skype adjust my audio settings" option is checked in Audio Settings as shown below:
If you still cannot see or hear the other person, it can be due to a variety of possible issues, including:
  • Windows or third-party firewalls
  • Your internet service provider (AT&T, Comcast, etc) could be blocking certain services.
  • Missing Windows system components.
Jan 10, 2009 | Logitech Quickcam Chat Webcam
It zooms really close to my face
1) Launch QuickCam software, just goto Start>Programs>Logitech>Logitech QiuckCam.
2) Press the "Change Settings" button, and in the Settings page, just choose the manual focus option, and adjust your focus until the image is clear.
YBC (/\)
Oct 08, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech Quickcam Communicate Delux Auidio Problems with Skype
I had a similar problem, the solution was as simple as not playing your voice through the speakers. The problem sounds like one of feedback. There are companies that sell phones that hook up to your usb port and will not cause this type of problem. Another solution may be lowering the volume on your mic.
Aug 20, 2008 | Logitech Quickcam Chat Webcam
Logitech QuickCam Fusion Webcam Logo
135 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
