Sharp VZ-2500 repair
Hello I have a SHARP VZ-2500 system that needs work doing to it;  such as new turntable belt, cassette heads replacing, bulbs etc... Is there anyone who's a specialist with these on this site who could help the audio repairers once they begin work on it? Many Thanks.
  • Anonymous Jan 24, 2009
    i gi have the same problem, found the band on ebay but i need more parts.
silly girl
  • 513 Answers
SOURCE: Cassette Player
Motor speed needs to be regulated by PWM. Reducing the current (with a resistor) actually lowers the torque - which, with a given load, does result in reduced speed - however, different length tapes (60min vs 90min), as well as different quality, and even current position in the tape, will change the load and hence the speed. You need to regulate the speed via PWM. It's sometimes done on a small board built into the motor, in which case you'd have a round hole into which you could insert an INSULATED screwdriver (tiny flathead wrapped most of the way in electrical tape works). It may be done on the main board, in which case you could find a pot conveniently labeled "motor speed", or perhaps "pulse width" or "pwm" or something to that effect. Find it, mark its current position just in case, and turn it to see if it gets the effect you're after. And there are some tape decks in the world with no speed adjust - they are designed with a specific speed motor and the sizes of the wheels and gears are calculated for that speed. Also there may be a mechanical fault/malfunction causing the speed problem. An initial check and thorough cleaning of the capstan and pinch roller should be done. If there is a buildup of tape oxide or a piece of a broken tape wrapped around the capstan, the tape travel will be too fast (do to the effective increase in capstan shaft diameter). If the pinch roller isn't fully engaging, the tape can be getting pulled onto the takeup spool at a speed faster than the capstan control. A different source of trouble might be a slip clutch (possibly an idler/clutch assembly)which is binding, or otherwise not functioning the way it should. Another type of motor doesn't have it's speed controlled by an internal or external voltage.. instead, the motor has an internal centrifugal speed controller. This type of motor can be found on older tape decks, and might not have been utilized more recently. Good luck
Posted on Mar 14, 2006
SOURCE: sharp wf 940 portable cassette / radio player
inside radio there is relay near power supply. change it and then radio will work. or clean it.
Posted on Mar 20, 2008
  • 4234 Answers
SOURCE: Philco turntable CD with cassette
Most of these are blet driven and the belt is probably slipping. This is a relatively simple repair if you have the correct belt. I'm in Massachusetts, so I don't have any particular recommendations for you. The belt will cost around $10.
Dan
Posted on Mar 21, 2008
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
http://www.donberg.ie/warehs/groupba.htm
try here
Posted on Jan 18, 2009
SOURCE: how do I put back the belt that slipped off my turntable?
I had the same problem & came up with this solution. It is very simple.
Take the platter completly off the turntable by pulling on the nipple in the middle of the platter. If you are unsure what the platter is it is the base that the record lies on. It may take a good pull to get the platter off.
Take the belt completly out of the turntable. On the underside of the platter you will see a large circular lip. Wrap the belt around the exterior of the lip. Make sure that the belt is flat & not twisted.
Inside the turntable you will see a large round white gear. On the edge of this gear you will see a semi circle cut out of it with no teeth on it. Align this groove facing front & center of the unit. You can feel it pop into this natural position.
Take the platter & on the underside you will see a small white gear in the center. On the bottom edge of the gear you will see a square notch. This square notch needs to face the front & in center of the unit.
On the inside of the turntable there is a small white wheel on the right side near the record player arm. This is where the belt has to wrap around. This is the motor.
Take the platter & sit it on your lap with the underside facing up. Align the square notch that's on the gear so it is facing 12 o'clock. Pinch the belt at 3 o'clock and pull it a couple inches away from the lip.
Now flip the platter over & be prepared to install it in the unit.
With the belt pinched away from the unit slip the pinched portion over the the small white wheel that is the motor. Put the spindle that is in the center of the platter into the center hole of the turntable. Make sure the belt does not get twisted & that the belt is still on the outside of the lip not getting pinched or hanging off. Remember to keep the square notch that is on the the underside of the platter facing front & center. This step may take a few tries so just be patient.
Now push the center of the platter all the way down as far as it will go.
Turn on the turntable & enjoy your vinyl!
Posted on Jan 31, 2009
I need an owners manual for The Thomas Pacconi Classic Model # TPCMSE 805 for my 82 year old father who has lost his and it needs a new phonograph needle and the cassette player is not working.
not sure about a users manual or other parts unit is belt driven
you can by the stylus
turntableneedles com
http://www.turntableneedles.com/THOMAS-PACCONI_c_50123.html
some thing easy diy if no sound while playing a cassette
try cleaning the head (silvery bit )
of the cassette player with cotton bud and metho
Jul 02, 2016 | Audio Players & Recorders
How to replace a belt on a turntable
Generic instructions for replacing a belt on a turntable such as yours are here:
http://www.gbaudio.co.uk/data/belts.htm
If you have trouble lifting the platter off, use the finger holes and lift. A gentle tap on the spindle (with the handle of a screwdriver, for example) ought to free things up.
Oct 28, 2014 | Audio Players & Recorders
Hello i have a sharp projector model xv-z21000 my
mainboard is not work ,it need to be repaired
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 14, 2013 | Sharp XV-Z21000 DLP Projector
The turntable belt wasn't atached and i need th know how to put it back on.
Good day. Lift the rubber mat off the platter and notice the two rather large holes in the plater. Put your thumb and forefinger through the holes and pull the platter off the turntable unit. Place the platter upside down and notice the inner rim which holds the belt. Place the new belt around the inner rim and replace the platter onto the unit. Now, with tweesers, working through one of the large holes, pull the belt onto the spindle motor. Once on, spin the platter by hand and make sure the belt does not slip off. Hope this helps
Mar 30, 2011 | Crosley Entertainer CR-79 Turntable, CD,...
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
I bought a nice jensen home audio system with 3 cd changer belt drive turntable and dual cassette. When i got it home i tried to play a cd and it wont read any cd past track 7 please help
If this is an old set then it is possible that the optical head is weak, the servo is faulty or the mechanism is jammed.
So open and clean head, check to see if the optical head moves well into the mechanism if not clean the gears.
If none of these work the optical head is faulty.
replace with correct procedure.
Sep 13, 2010 | Audio Players & Recorders
I need a replacement turntabl drive belt for a SHARP SG-450E Hi Fi system, any idea where i can get one from please
Generic replacement belts are available from a number of suppliers, but you need to know the dimensions of the original. My cross-reference guides for a couple of companies don't list your Sharp model so I can't give you a specific part number. You might try taking the old belt to a service shop. If they have a belt gauge they might be able to order a suitable PRB brand or equivalent replacement for you.
Doing a search for your model turned up this vendor (in Australia!) who claims to have the belt in stock. They offer international shipping, so maybe this would work for you.
Good luck, and thanks for using Fixya!
Feb 03, 2010 | Audio Players & Recorders
CD Changer/turntable MDL Fisher DAC-145.
Hello....Give you local SEARS store a call and inquire...I've used them in the past...Their repair center does excellent work and repair more brands than anyone I know....If there are any up-front costs...they'll let you know...Try it and let me know....I hope this was helpful......PEACE.......
Feb 06, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Belt on turntable needs replacing
should have a retainer clip of some sort right in the center of the platter. Should look something like this, you will need to take it off first.
Jan 29, 2009 | Sharp Audio Players & Recorders
482 people viewed this question
 Grubhead
Grubhead
