When i try to change text size from smallest to largest no change.only change when i press ctrl/plus button
SOURCE: Not Loading
i m sure its some kind of maser problem with u r system...
because at the 1st time when u select safe mode it should work .....i think some big data dammage have made....and now u are unable to recover it....
so my suggession is that u can re install win xp on u r computer..
regards..
for any quarry u can mail me at-[email protected]
SOURCE: When I turn my Compaq
try to enter setup.. try saving it to factory settings, then restart ur computer.
SOURCE: HP Pavillion e2200 desktop--Vista. I
What is your setting set at, can you list the actual number x number?
With screen resolution the smaller then numbers on the setting, the bigger it will appear on the screen. If you set it to higher numbers you should get the results you are looking for.
SOURCE: HP Compaq Presario SR2013WM ...Power Problems ?
Unless the power button sticks or does not pop back out, i doubt the issue is in the switch, but it can be tested by replacing it with a momentary switch from Radio Shack (not an exact fit, but good for testing)
This sounds like a power supply issue. That would be the first thing to check. If it is NOT connected to anything except the power cord , it shouldn't run unless switched on.
Could also be the motherboard, but before you start dismantling the computer , check the obvious. Open the case (usually to screws on the back) inspect all the cables, reseat your ram chips and addin cards.
Not to scare you ar anything, some of these presarios have bad capacitors on the mother board. coupled with the fact that they are difficult to clean (inside) and airflow is not maximized in the case, they tend to cause the capacitors to swell and leak, losing voltage.
When you are inspecting the insides of your case, take note of any capacitors (little cans with crosses on the top) on the main board inside around the CPU fan that are swollen or leaking.
If you find these in bad condition , i would replace the motherboard.
SOURCE: Hi, Im having problem booting my COMPAQ PCs
hi , your first machine needs a hard drive disc error check performed (C drive/properties/tool/error check and tick the 2 boxes ).
the second machine needs the bios battery replaced .
hope this helps
