Question about Astar LTV-20PW 20 in. EDTV-Ready LCD Television
I need a driver
I changed my old monitor for this Astar 20" LCD. Withiut changing drivers it "sort-of works(I see pictures OK, but, the words come out like russian) I'm trying to fix the video without being able to read the screen. the auto driver fixer isn't changing the driver.
The problem was fixed by lowering the screen resolution. The default it was trying to use was too high for the monitor.
Posted on Nov 22, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi go tru my computer property, hardware, device manager & display.unistall the display adapter & restart ur system
Posted on Nov 09, 2008
Looking for drivers to use this monitor with Fedora 20 Linux OS
You don't need drivers. You need to adjust the resolution and refresh rate. If you plug in an old CRT monitor then Linux will probably boot and you can edit the conf file to change the settings. Most LCD monitors require 50-60Hz refresh rate.
May 05, 2014 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
White screen after about 20 minutes of operation
key words above, (change(d) PC) did you mean you changed out the PC, and it fails, I will guess yes) as in past tense?
old old , 1710s, most are now dead, you know that right?
all have CCFL tubes in it.(problematic for sure)
and had a sleep mode inside, (problem 2) sure.
so with PC turned on, the push the menu key
and turn off the sleep timer, keep it off for ever.
it is not compatible with NEWER PCs at all.
the Monitor is bad,
if cable and pc are ok, the monitor is bad.
you proved that, if change = changed. above.
like this. (GO LED !) avoid all monitors older than year 2010 !
https://www.walmart.com/ip/Asus-LCD-VS197D-P-LED-Backlight-18-5inch-Wide-1336x768-50000000-1-5ms-VGA-Retail/20701019
Nov 06, 2017 | HP L1710 LCD Monitor
When the monitor is turned on it appears to work - the "acer" name comes up and then the words "no signal". As soon as no signal comes on the sceen it goes to black and the light turns...
You might have one of several problems.
Your monitor might require a driver for your computer/graphics card in order to show up.
Your monitor's input might be slightly damaged.
Or your graphics card might not have the proper drivers in order to display on that kind of monitor.
I would go online and make sure your drivers are up to date for your graphics card first, then inspect your monitor to make sure no pins from the cable have broken into the input, and then make sure that your monitor is compatible with/without drivers to your graphics card.
Mar 16, 2011 | Acer LCD Monitor X223W
I installed Windows 7 recently, but I could not get my Monitor to change resolution. I had the latest drivers (2.0 but that was created in like 2003) and the computer still would not recognize it. The...
There are 2 things that directly effect your resolution, 1 is Monitor Driver and the other is Display Driver.
The Monitor driver isn't so important as the Default Monitor driver also works well.
You need to confirm that your Display drivers are up to date, Tell me your Desktop system, and I'll find you the Latest drivers (If available) for Win 7.
I hope you understand.
Regards, WAQAR.
Nov 20, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Plugged in a new 23 inch LG LCD Monitor and cannot get picture
In additio to the fine help given by Mister.
If you have a DVI output on your computer get the cable for that and this will greatly increase the quality of your display.
Your graphics card should be able to autodetect a DVI monitor and suggest the best display type.
Sep 16, 2009 | Computers & Internet
TV will not come on
Hello, Your tv main board is defective. just call me at 323-767-6030 and I will help you go through the trouble shooting.
Jan 11, 2009 | Astar LTV-20SD 20 in. EDTV-Ready LCD...
Astar 32'' LCD - anyone have monitor drivers?
I purchased this model
http://www.newegg.com/Product/Product.aspx?Item=N82E16889114016
and have been able to get 720p and 1080i resolutions on DVI connections from my PC with both Intel and ATI graphics AND 1920x1200 resolution over VGA from the Intel integrated connection (the ATI has only DVI). You need to dump the EDID to see what resolutions and timings the TV is telling the video card it supports. Then you need to get a video card driver that allows for custom resolutions to be created. First download this free utility and post the output: http://www.entechtaiwan.com/util/moninfo.shtm
Nov 16, 2008 | Astar LTV-3201 32 in. LCD Television
No Picture or Sound from ASTAR 32 inch LCD Television
There is more than one problem with. A it could be the main board that finally gave out. B the power board in your TV is not work, and now you can see a picture. Depending on how it's connect the screen could be burn out. but just what type of light comes on when you try to turn it on. if the green light comes on and stay on then it has to do with the picture not the power if you need help narrowing down the problem you can call 226-2211 My E Discounts. I'm a tech and we work with a Astar TV from time to time.
Aug 28, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Preset
Without knowing any more about your system I can only give you a couple of general ideas.
First try updating to the newest video card drivers possible.
You can try going to the drivers tab in display adapters in device manager and click update drivers.
Failing this, if your system is more than a few years old you will probably have to update to a more current video card to get the resolution that you need.
The native resolution for your screen is 1280x1024.
Jan 03, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Astar LTV-20PW 20 in. EDTV-Ready LCD Television Logo
109 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
