Question about Brother IntelliFAX 1270E Plain Paper Fax
2 phone lines causing problems for fax machine
My problem is more of a question
we have a Brother Intellifax 771 fax machine , they have lost the operating manual , they seem to have thought that they needed a dedicated line for this fax machine which they did get, and it worked fine for a while, then they started having problems, then I come along and they ask me to look into it
I say they should get rid of the other line and run their phone and fax line on the one line, their office is not a busy one, am I correct?
Bruce
  • adamsfamily7 Nov 11, 2008
    than you!
  • Anonymous Nov 12, 2008
    we have a dedicated fax line (along with our home phone line) and just recently found out that about 9 out of 10 times our fax senders get a fast busy signal when the try to send us a fax. help! we have a brother MFC-3340CN.
    Genius:
  • 2,120 Answers
Fax machines are designed to have their own dedicated phone line.
Posted on Nov 09, 2008
Our IntelliFax 4750e will not receive faxes. The line has a dial tone, and rings when called. It is set to "fax" and not "fax/tele." Suggestions?
There are a few possibilities. 1) The phone cord coming from the wall is plugged into the phone port on the fax instead of the Line port. It should be on the line port.
2) The fax have been set for distinctive ring. This causes the fax to ignore the normal incoming ring tone and is instead waiting for the distinctive ring from the phone co.
3) The modem in the fax has gone bad. If you have had any power failures or electrical storms/problems this is a possible cause.
Some models will also not answer if the machine is out of toner or paper.
Oct 21, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Don't know how to set up brother intellifax 1840c
Plug the fax phone cord into the LINE port of the machine. The rest is automatic.
Jan 16, 2009 | Brother IntelliFAX 1840C Plain Paper...
Can only recieve some faxes
this sounds like may be there is a phone line problem on those two machines or that line is there dial tone??may be you need to have local phone company check this out
Dec 31, 2008 | Brother IntelliFax-2820 Laser Fax
1 line is fine as long as the fax is set to auto recieve mode
Nov 12, 2008 | Office Equipment & Supplies
Phone line goes to fax, then ans mach...now caller ID won't work.
Set the reception mode to Fax with answer machine TAD. Make sure its set for fax with answer machine.
May 29, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 1270E plain paper fax
It could be either. take the machine to anothewr line see if the
error goes away.If it does not call brother customer service. There is an adjustment for input sensitivity of so brother fax machines. It may be in your operators manual
May 27, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
The brother Intellifax 2800 intercepts other faxes
Make sure that the proper phone number is installed in the fax.Also that they are not sharing the same common line.
Oct 17, 2007 | Brother IntelliFAX 2800 Laser Fax
Unable to get my Intellifax 775 to receive any fax's
Make sure that the phone line is pluged into line on fax machine and not ext.
Mar 18, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFAX 1270E Plain Paper Fax Logo
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
