Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Water Leak at vent area in door...
Water is leaking at seal area of vent between door liner and galvanized inner panel. After dishwasher starts wash cycle water comes out through bottom of door and onto floor. No water is coming out through vent to outside of door. No water is leaking around soap dispenser. Any help would be appreciated.
  • 9 more comments
  • David Lehmann Nov 14, 2006
    Thanks, catriver, I replaced the wax motor, it appeared to work OK, but apparently did not close the vent door fully. This corrected the water leaking down from the vent, however we still had a leak coming from the bottom of the door, found that the lower spray arm was beginning to split, causing water being forced under the inner door panel and leaking at bottom of door. Thanks again for your help.
  • beewatcher Dec 16, 2008
    I closed the vent area off, but water still leaks out of the bottom of the door. This under counter Model #DWU9200ABX, we think its over 20 plus years,
  • Anonymous Mar 12, 2014
    Water is still coming out of the wands when I lift the doors when the cycle is complete.
  • Anonymous Mar 14, 2014
    Water leaking from bottom of door on my kenmore dishwasher 17772990
  • Anonymous Mar 21, 2014
    water is coming out at the front door of dishwasher
  • Anonymous Mar 22, 2014
    I took front of door off while the washer was in wash mode the water was leaking there are 3 holes in front of door for water to circulate I could see water leaking how do I stop this?
  • Anonymous Mar 23, 2014
    What do I do?
  • Anonymous Mar 25, 2014
    water leaking down the dishwasher air vent
  • Anonymous Mar 28, 2014
    I have a Kenmore Model #665.13193K902 that is getting the insulation wet on the left side which is also leaving a water stain on the outside wall of the cabnet next to it. There is a hose loop located in that area but it is not leaking. This model has a vent on the top of the door on the left side. No water on the floor just wet insulation. Is this a vent problem? Should I not use the heated dry feature?
  • Anonymous Mar 31, 2014
    Water coming out between bottom of the upper door and top of lower door
  • Anonymous Apr 01, 2014
    when dispensing, water was pouring out of the front door handle and from the bottom of the door
    President:
  • 878 Answers
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Posted on Oct 23, 2006
Dishwasher Leaks
Find a new repair person
Apr 07, 2017 | LG LDF7932ST Dishwasher
I have a kitchenaid dishwasher model KUDMOITJBLO installed as new unit in Oct. 2002 in a new home. Current problem is water coming from front door, bottom as unit starts wash cycle after filling. Leak is...
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Water Pouring out of door, appliance stuck on wash
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked.
Some common leaking trouble makers....
Leaks at the door:
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket
for parts you can get it from
www.repairclinic.com
Nov 21, 2009 | Candy Dishwashers
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Split spray arm
Door hinge(s) bent
Drain hose is split
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
KitchenAide Dishwasher KUDS01FL leaks water
i have had mine leak (usually out of the left side) I can see it coming off the black rubber seal that ends about 2/3 of the way down the side. ( I have also replaced the inner seal around the tub- that helped as the bottom of the seal would stick to the door when closed and make a gap for water to come out) I also notice that water and moisture comes out at the top of the dishwasher (then it leaks down the side and front) I have heard of many problems with the latch...and I can push mine closed tighter but it doesnt close completely with just the latch, but enough for the wash cycle to work. also just make sure there are no crumbs or something stuck around the liner. good luck mine has been a lemon and i cant wait to get a different brand.
Jun 18, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Door leak
Br, couple of things you can look for here. Check the vent, you can just pop this out. Sometimes there is a buildup of gunk which will hold water during wash and leak down between the door. There is a seal there, part number 974782. Another thing is to check the upper spray arm for cracks or splitting. This can send a direct flow of water into the vent. There is also a seal at the bottom of the upper spray arm, part number 3376846. I was fooled by a leak like this once, it turned out to be a clogged vent...Catriver..post back.
Sep 30, 2006 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
1,065 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
