Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Black Screen with White Randomized Pixels
My Mitsubishi WD-52525 DLP worked fine for 4 years...now, one day the screen is black with white pixels flashing. I hear sound on all devices...I can also see the device menu, but none of the devices show picture.
Any help?
  • Anonymous Nov 09, 2008
    I have the same problem. I just had the lamp replaced a month ago and all was fine until last night. I saw some flickering on the screen now not only can I not see a picture but only flickering, but all other input devices like dvd player and xbox have skewed pictures. Any suggestions?
    Please email me back at soniram74@aol.com.
  • 64 Answers
Not sure...but the inputs (and related circuitry) on Mits are notorious for failing due to weak components. Test to be sure that all inputs are dead? If so...this may not be an easy fix.
Posted on Aug 01, 2009
    Sniper:
  • 53 Answers
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
How do I fix pixels on my tv screen
Usually solved by replacing the DLP chip (Google it) they cost around 180. If you have a couple hundred more I'd just go buy a Samsung LCD smart tv.
Feb 21, 2015 | Mitsubishi WD-65735 Television
How do I remove a white spot on tv
Spot remover. Black marker? Maybe not. (;^D).
Really, if it's just a little white dot on the screen, it may just be a bad pixel. Those things happen. The manufacturers warranty against more than 'so many' bad pixels, but if there's just one, I doubt they would replace it. If it's a big block of white, you might be able to get it replaced.
Oct 19, 2014 | Mitsubishi WD-65737 Home Theater
Repair dead pixels?
Dead pixels can not be repaired.
The model# WD-52525 you provided is for a DLP TV.
If you are seeing white dots on the screen it is due to a bad DMD chip or light engine. Unfortunately, it is not a cheap fix.
Good luck
www.aaatvservice.com
Aug 10, 2014 | Mitsubishi WD-52525 52" Rear Projection...
White dot in the middle of the screen
you have a bad dlp chip hear a link for you so it will help you to unstay.
how the light eng http://www.youtube.com/watch?v=eyAykjZ3zs4
Dec 23, 2013 | Mitsubishi WD-52525 52" Rear Projection...
White dots on the right side of the screen
these are called dead pixels if your television is under warranty you should replace it with new one cause dead pixels generated new ones until it will fill up your screen completely.
May 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have white pixels showing up on my tv, no black pixels yet. how can i diagnose this issue and what can i do to fix it? Mitsubishi WD-65733 dlp tv
riddic759546,
Sounds like you have a bad optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 05, 2011 | Mitsubishi WD-65733 65" HDTV
Sir, its white small dots on complete screen, like sky with stars,
Place a white piece of paper about 1000mm in front of the screen and focus the image sharply.
Choose menu, image, advanced then select color manager.
go through the color options and check if some pixels are permanently on or off (ie small dots or black) instead of a uniform colour on the screen.
The DLP chip is most likely the faulty component
Mar 01, 2011 | Vivitek D825MX Projector
I have a Mitsubishi WD Y-657 that started out with a single white dot. Now there are over 50. This all happend in a week. I believe they are dead pixels. ?? What to do?
Dead pixels are a problem with LCD screens. You have a DLP set, so this is not possible. I unfortunately don't know anything else about this problem.
May 16, 2010 | Mitsubishi WD-Y657 65" HDTV
Little green and white boxes on the screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Found it right here http://www.discount-merchant.com/MITSUBISHI-RMD62-939P977A20-Light-Engine-p/1138084.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
White and Black "pixels" all over screen
try to reset press menu 123 enter if not sounds like a engine big bucks.
Apr 10, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
