Question about XFX GeForce 6800 GT, (256 MB) Graphic Card
GeForce 6800 Fan Stopped?
So i bought a brand new power supply so i could beef up my power output for future upgrades. After taking half the computer apart and putting back together with the wires in place i turned it on and now i have no graphic card fan working. Utility partition says its getting power to all parts of my computer but the cards fan wont work...i don't have the money to upgrade GFX cards...is there anyway i can fix it?
  • demonrich Nov 10, 2008
    my graphics are also working just fine...its literally just the fan wont work. Got it to spin a little last night but only for like 30 seconds then it stopped again. sounded like a sick engine revving a little then dieing.
  • demonrich Nov 11, 2008
    Thanks! 1 card fixed ^_^
  • 189 Answers
Greetings!
Remove the graphic card from the board, at the top of the fan of your graphic card there is a sticker remove it slowly, then put a small amount of oil (the finner oil for machine) in it, turn the fan so that oil may goes to the bearings.
Return the sticker, and install the graphic card on the board.
Thanks
Posted on Nov 10, 2008
Video Card upgrade
as i can c you have a power suply of 200 wats in your pc (correct me if im not right) the GeForce 9400GT is proved not to use a lot of power. but the problem is that your pc is small and it would not get enough ventilation unless you buy a separate fan try it out
Dec 14, 2009 | HP Compaq dc7600 Small Form Factor PC...
Monitor stuck in Power Save Mode
yes look like your nvidia run out of juice you can look at nvidia 7200 le or maibe 8200 gs that will be a reasonable price / quality grafics cads for a upgrade of the 6800 thanks
Oct 19, 2009 | Dell XPS 400 PC Desktop
I was running NVidia GForce 6800 dual dvi card when while playing WoW all animated motion on screen stopped. I was still able to type in chat for a short time, after which the letters became unreadable and...
Its may be the GPU problem.
It can be overcome by doing reflow technique.
You need to do following.
1. Uncover ur PC casing
2. Locate the nVIDIA PCI-E Card.
3. On the card, locate the power supply pin of GPU fan.
4. Remove the pin.
5. Switch on ur PC.
6. Still u may get scrambled display/wavy screen, but wait for 5 minutes.
7. Press reset button on ur PC.
8. Ur PC might work.
9. Switch it off.
10. Connect the power supply pin back as it is.
11. Power on ur PC.
thats all.
Removal of fan power, makes the GPU to get high heat, it a reflow technique.
Remember, not to touch the GPU portion (heat sink), as it may be in higher temperature.
Try this, it works most.
For Clarifications only:
gnaveendra@gmail.com
Oct 15, 2009 | Nvidia GeForce 6800 PCI Express Graphic...
New graphics card, no picture
1. Try to start in SAFE Mode by press f8 while booting. If successfull.
2. Press F8 again select enable VGA mode and continue.
3. Your monitor is not supporting the resolution reduce and restart it will work fine.
4 To reduce the resolution desktop right click, select properties goto tab setting - reduce resolution
Jan 14, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Display driver problem
This is a common sign of a driver conflict error. It usually happens when two or more drivers are requesting the same resources, or if the diver has become corrupted or if the driver was just plainly poorly written.
Below is a link to HP/Compaq's Driver update page for your computer.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=3644737&lang=en
The driver you want in particular is the Graphics driver (The 2nd on the list) Though you may want to update all that are not up to date(This would Lessen the likelyhood of future conflicts)
Another possible soultion might be to upgrade away from integrated graphics.
Hope this helps,
Dave
Nov 15, 2008 | Nvidia GeForce 6800 GT, (256 MB) Graphic...
Missing sound driver
How much power does your power supply give? It could be that your power supply cannot take the power of your videocard. They say it is recommended to have at least 700watts of power with that videocard as it consumes a lot of power.
Sep 15, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
Upgrade card
Well, these are the minimum specs for Age of Conan:
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
These are the specs of your computer (base):
  • Intel Pentium 4 550 (3.4GHz) Processor
  • 1GB PC2-4300 DDR2 Memory
  • Two 74GB WD SerialATA Hard Drives in RAID0 Drive Array
  • 16x DVD+/-R and 48x CD-RW Burner Optical Drives
  • Sound Blaster Audigy 2 ZS Audio
  • NVIDIA GeForce 6800 Graphics Card with 256MB
Seems to me that you are okay. Would a faster computer be better? Of course. But as you are, the game should play alright. Upgrading to an 8 series Nvidia is worth the change, though.
May 18, 2008 | Dell Dimension XPS Gen 4 PC Desktop
Is the 350 watt power supply ok for EVGA 6800 128 mb agp card ?
I would suggest at least a 400 watt power supply as the amount of peripherals you are running will soon take up the 350 watt supply, but go for a 500w as the price difference is negligable.
Mar 20, 2007 | Evga e-GeForce 6800 (128 MB) Graphic Card
Is the 350 watt power supply unit ok for EVGA Geforce 6800 graphics card ?
The big issue with a power supply unit rating is the total peak load that it has to deal with, which you calculate by adding all the rated loads of all the parts of your pc that are connected to it, and add yourself an extra 20% for luck. The motherboard, the HDD, the fans, the drives, USB devices, modem, and many more. If you have enough wattage left to accomodate your graphics card then it should be fine. If in doubt, for the cost it is always better to upgrade your power supply to a larger rated one, rather than overloading a smaller supply or causing low voltage problems with all your peripherals. Here is the link for your graphics card manual if you need it; http://www.evga.com/support/manuals/EVGA_GraphicsManual.pdf Check page 5 reference the supplemental power adaptor, and check your power supply has an connector for it. If you want to identify the power consumption ratings for each part of your pc, most will be written on the component somewhere, some in the manual, and some you have to guess by checking similar items ratings online. If you want help with this please post again and we can certainly try. Looking at the card, my guess is that a system that can justify such a nice card is likely to be pushing a 350w supply already, I'm guessing what your system could be like and I would put a 600w or more supply in it as soon as i had the cash to do so. post back all the details of your machine and i can figure it out if u like. This link takes you to some other interesting info about your graphics card. http://www.evga.com/support/knowledgebase/ Mostly a power supply that cannot deal with the demand will inform you by shutting down or committing suicide, although occasionally other components can be damaged by poor power supply, the chance is minimal with many newer items, and it should be worth trying. The fan performance of a power supply often governs how well it can deal with long periods of high load - give it a proper clean, and remember to check always that it is running. if you want, you can install another fan on the outside (blowing the same way), but unless you power it from a different source then you don't really help much. Instead of getting a larger power supply, you can just get another (perhaps from an old pc) and only use it to power the graphics card - best left outside the case for overheating reasons. Hope this all helps :)
GeForce 6800 Gt, Unusable signal
Could you post your system information as well? CPU, memory and so on.
Dec 19, 2006 | XFX GeForce 6800 GT, (256 MB) Graphic Card
XFX GeForce 6800 GT, (256 MB) Graphic Card Logo
599 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
