Hey, i have a webcam and my older brother does too,
there the same brand, but mine doesnt have Video effects?
and it says theres no updates, i really want video effects so i can mess with some friends,
i watched the Perview for how to use video effects,
but it doesnt help me any!
it says to double click on it, but when i do it takes me to my webcam where i can choose ..
Msn, AIM, Video Call, or Yahoo, with other stuff like,
Quick Capture, Windows Messenger, Video E-mail, My Logitech Pictures, More Applications, Control Panel
so theres nothing there to help me out
is my webcam too much of a old version?
help me out please?!?
If you have the "exact" same cam as your brother, and also use the "exact" same programs as your brother, then their is no reason why your cam would not work as your brothers.
Did you download the plug & play option for the cam?
Do you use the "exact" same version of windows as your brother? (Win 98, XP, Vista)
Lighting Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu.
webcam displays colours b> Webcams are useful in both personal and business functions, from video chatting to video conference calls. When your webcam displays strange colors, it is usually due to a problem that is easily fixed even without advanced technical abilities. By trying at-home solutions before sending the computer or camera in for service, you can save time and money.
Lighting Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu. On a Mac, effects for the built-in iSight webcam can be changed in the Effects 1 and 2 menus in the Photo Booth application. Hope this helps.
I just got the same problem with mine in fact my webcam built into my asus G73 laptopp in my webam i am in color only when the laptop is tilted up and when i lower the screen i turn black and white. I called customer service and they are replacing it. the problem would most likely be a messed up ribbon cable for your webcam. i am actually taking it in to be looked at today.
Make sure you have Microsoft DirectX installed The features you get with your webcam depend on your OS Check out what you have by launching the toolbar and clicking on the Video Effects menu ( 2 theatre masks )
right click on ur web cam video window and choose video settings, You should have a window with all kind of effects that You can add- hit apply and OK when you done
