Question about GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo...
Door hard to open
Door is extremly hard to open. has gotten so bad that you must have shoes on & pull on the handle at the same time. any help would be appreciated. thanks
  • Anonymous Nov 21, 2008
    trash door is hard to open
  • didipolonski Feb 04, 2009
    The fdoor foot switch mechanism is cheap and unreliable. This trash compactor is only 2 years old and is already falling apart and is inoperable.
    The pedal/foot switch is held in place by two sheet metal screws that hold the pedal in place, thru the sheet metal side rail. One hole has worn out and the other side is egged out.
    Is there an upgrade to this system? This pedal activated switch system is not very good. It is cheap and difficult to use.
    My old Kitchen Aid trash compactor lasted over 20 years. It seemed sturdier and it was almost identical to this trash compactor ( minus the stainless steel). It also had a really nice feature for maximum compaction, which this one does not have.
    Please advise
    Sergeant:
  • 229 Answers
The tracks that the door are on have to be cleaned and lubricated with WD40 or equivalent. This should solve your problem. Hope this helps
Posted on Nov 09, 2008
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the sheet metal side rail it's attached to.
Dannys00
Posted on Dec 25, 2009
  • Nadine Howell
    Nadine Howell Dec 27, 2015
    Dannys00, thanks. how did you attach the L bracket? Nadine
Same problem here. My unit is also two years old and is very difficult to open, my wife and kids can no longer activate the foot pedal. The tracks are clean and lubricated, the issue is the actual foot pedal. I've tried tightening the screws, which were loose, but that hasn't helped. Has anyone resolved this issue?
Posted on Dec 19, 2009
  • scottyburns Aug 12, 2011
    I have the exact same problem. Did you ever resolve it?
2010 Ford Escape hatch door will not open. Glass panel will open but not big hatch.
in most cases the latch under the door is seized. if this is the case you will have to get inside and remove the inner plastic panel to look in with a light. around the middle of the door on bottom you should see the latch . lay a piece of cardboard or rags down to catch the mess of oil.squirt lots of penetrating oil and transmission oil on the entire latch, really soak it.there should be a rod coming down from the handle to the latch. try pulling up and down with a pair of pliers or vice grips. it may take several tries but should release. depending on how bad it is seized you may have to push hard or hit with the soul of your shoe.be careful when you push that you don't fall out.after it opens you will need to work the latch several times to make it work good...good luck
Nov 05, 2017 | Ford Cars & Trucks
When I try to open garage door, Model Genie 2202, the chain moves and then pulls and there is extreme tension on the door, and I stop the door fro trying to open. Can you help e please?
Pull red handled rope and free trolley. See if you can open door by hand. If you can't your door may be in a bind or the t springs have came loose or broken (DO NOT USE A WRENCH OR ANY TOOL TO SEE IF THE SPRINGS ARE WOUND.YOU WILL BECOME INJURED IF YOU DO) A trip to ER will more than pay for door company come and fix it for you. If your door has 2 springs you can compare them in size). TORSION SPRINGS ARE UNDER GREAT TENSION AND RELEASING THEM IS A BAD IDEA. DO NOT ATTEMPT TO UNWIND THEM IT REQUIRES A SET OF WINDING BARS.
Aug 17, 2017 | Building Materials
How do i remove door panel to get window runner
The panel is usually a pop button type retainers holding the panel on, Obviously all screws will have to be removed ie; grab handle, internal door opening lever, and the window winder,
TIP remove window winder handle with a shoe lace or a lenght of thin material , it's a horseshoe shaped spring clip holding the winder handle on and pulling the shoe lace or material in the opposite direction of clip will easily remove clip (don't loose ) Good luck
Apr 10, 2010 | 2003 Nissan Se R
MY ACCENT REAR NEARSIDE DOOR WILL NOT UNLOCK, HOW DO i REMOVE THE INNER PANEL WITH THE DOOR LOCKED . OR GET THE DOOR OPEN
It wont be pretty but examine other rear door and be familiar with retaining fixings,ie door grab handle , window winder , and any screw fixings .
Remove what you can and maybe the rear seat also (sorry) The window winder removal is easier than you think ! It's held on by a horse shoe shaped spring clip, remove with a simple shoe lace or narrow piece of cloth pulled in the opposite direction of the horse shoe clip.(don't loose) This is about as much as I can help you , after this it's a tug and pull (against snap fixxings) upward lifting motion of the panel. Good Luck
Apr 05, 2010 | 2000 Hyundai Accent
Driver side door extremely hard to open!?
It's a common problem on this model.
I suggest to have it fixed shortly otherwise you might be unable to open the door one day or another and it's not easy to remove the door trim to fix the problem when the door is closed.
The door external handle and the latch have to be replaced to fix it permanently. Unless you are a very patient person and likes puzzle and ready to spend few hours to remove the door trim and figure out how the levers are connected and so and so I would recommend to have it done in a body shop. Usually they are familiar with these mecanisms and will be less expensive than a dealer.
My estimate, $80 for the parts + somewhere in between 1.5 to 2 hours labour.
Hope it will help
Dan
Dec 20, 2009 | 1998 Ford Explorer
THE FUEL DOOR ON MY 92 CIVIC DOES NOT OPEN WHEN I PULL THE HANDLE, HOW DO I DETERMINE IF THE HANDLE OR THE CABLE IS AT FAULT. THE HANDLE ASSEMBLY HAS NO SCREWS VISIBLE, I DONT KNOW HOW TO TAKE IT APART
basically the linkage connecting the handle to the door is probbally worn. The cheapest option is to open the door manually, pry it open with a screwdriver or smoething flat and stiff. Look at the door and thhere should be a metal tab where the door catches the linkage. Just bend back that tab and your door should be fine. If you dont want to do that try to get some PB blaster and spray the linkage.
Aug 09, 2009 | 1992 Honda Civic
Doors extremely hard to open on both refrigerator and freezer
What you have is normal - it is intended to make a tight seal - something similar to pressurizing an airplane.
You should be able to get back in with no problem after about 30 seconds - time it on your watch
And wipe the vaseline off - it is both counter productive and may cause the plastic in your door seals to degrade.
Jun 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Passenger door won't open
most common problem with replacing door handles on these is that you will encounter allignment probs for main catch which this sounds like. if you attempt to open from the inside then try putting lots of pressure on it till it should give way. once you acvhieve this, try looking at the very end of the door with the catch on. if you take a key and roll the latch till it locks and lake sure it is not too far into the mechanism, dont worry simply pulling door handle will disengage it, but once it is shut like this it is extremely difficult to undo.
Feb 24, 2009 | 2000 Chevrolet Silverado 1500
Doors are messed up
If you can get to a local junk yard or you could try a parts store, and get yourself new/used (but not stretched) door handle cables. What has happened here is the cables in your door have become stretched, to the point where it takes a lot of work to open them. If a shop will do it for a reasonable price I'd go ahead and do it. If not roll up the sleeves and try not to get too frustrated because, this job is easy however it can get to be a little frustrating your first time around.
Feb 03, 2009 | 1995 Volkswagen Golf
2004 model - locks jammed
It sounds like the latch on your door is in the closed position. to fix this, first make sure that the door is unlocked, then pull on the door handle( as if you are trying to open the door) then at the same time using your finger or a pencil open the latch on the door. (try closing the door)
Sep 18, 2008 | 2007 Volvo C70
GE Profile GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... Logo
1,524 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
