Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS-55809 2-2 code
I have a mitsubishi WS-55809 with a 2-2 code. I think the IC's may need replaced but I have to check to see if the fuses are blown first. Do you have a schematic or any additional information that would be helpful in troubleshooting this problem?
  • Steve Sampaio
    Steve Sampaio Nov 10, 2008
    I pulled the board and the fuses both checked bad. Can you verify the the convergence IC's are labeled IC3E01 and IC8A50?
    thanks for your help!
  • Steve Sampaio
    Steve Sampaio Nov 27, 2008
    I replaced the IC's and the pico fuses. Tested the board and all tests well. when I power up the TV I get a 1-2 code now?? Any ideas??
  • Mitsubishi Master
  • 8,617 Answers
Look on the center board where the ics are and check F9A04 and F9A05 pico fuses, if they are blown you will need to replace those two 5 Amp picos and the convergence Ics
Posted on Nov 09, 2008
  • Sonny Berry
    Sonny Berry Nov 10, 2008
    the convergence Ics are IC801 and IC802 they are stk392-570
  • Sonny Berry
    Sonny Berry Nov 27, 2008
    check the wire clips to see if they are all secure and hooked properly, as a 12 code means no error detected.
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Ws 55809 color
So you are still haveing the convergence issue with your tv, the convergence ic chips need to be replaced to correct this problem you can't adjust it as the components are failing.
Aug 19, 2008 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi ws-55809 will not turn on
The problem is the Convergence circuit and the reason it does not power up is that one or two of the 5a pico fuses have opened when the Convergence IC failed. It is either going to be a pair of STK392-570's or a single IC STK393-110. That is as long as this set is a Mitsubishi made in the last 7 to 9 years.
I would estimate the cost to repair 280.00 plus service call fee if any, plus tax on parts.
Let the Tech check it out. If if it cost less than 400.00 to repair, it may well be worth taking the chance.
thank u
rate me
Jul 21, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I just replaced the 2 ic chips (stk392-570) and the 2 pico fuses at f9a04 and f9a05 that were blown. The tv powed up for about 10 seconds then turned off again. Now i'm getting the same 3 second power...
You have bias resistors close to the IC's, I would guess you have a few that have changed in value and therefore have destroyed the IC's again. Now you must start over again. The resistors will be very low Resistance and tolerance and they must check exact.
Jun 04, 2009 | Mitsubishi WS-55809 55" Rear Projection...
55809 convergence
Mar 16, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 installing STK392-570
un solder ics replace both of them resolder make sure you do not solder any of the circuits together or it will short something out,also ck low ohm resistors in same circuit.I will try to help you the best that i can. Main key you must know how to Solder.
Dec 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws 55809
Its a STR-G6632 the mitsubishi part number is 267P151010
Oct 24, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws 55809
22 is short protect usually its the convergence Ics in that model that can short out. check fuses F9A04 and F9A05 if they are open its most likely the convergence ICs that need repslacing. If you need further assistance, please reply to this same post.
Jul 29, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
266 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
