Question about RCA DRC8030N
RCA DRC8030N No output
The unit worked fine until the warranty ran out, then the output quit. I have tried many differemt connectors and ways of connecting, Nothing. I did ger the menu to flash, but that is all
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Posted on Nov 16, 2008
My RCA DRC8030N will not do any thing but read Hello .
Can anyone help?
Posted on Jan 09, 2009
Unable to properly connect the DVR with our specific A/V system. Request a current/new manual for this device (RCA DRC8030N) since we lost our original owner's manual. Would like to connect the TV with...
George-
I do exactly what you are trying to do. I take the outputs from my cable box (3 cables: comp video, left audio, right audio and plug them into the 8030 respective input sockets (input 1 on the back). Then I have the output video cable going to the TV. I connect the 2 audio outputs on the recorder to my stereo input for both audio channels so that the audio comes out the stereo system speakers. I use the AUX input to the stereo system for this. If you are using the RF from the source, then I think the same output from the recorder setup should work for cabling. Make sure the 8030 has all the right inputs/outputs selected in the main menu setups.
I hope this helps.
Jacques
Apr 11, 2009 | RCA DRC8030N
RCA DRC8030n Owner's Manual
Hey jacquesnoir,,
I can email you a copy of the manual..
bigsteve1962@excite.com
PLEASE put "RCA DRC8030N" in the subject line otherwise I will delete the message and you won't get the manual... I get quite a bit of junk at this address so be patient..
Steve
Mar 27, 2009 | RCA DRC8030N
Larger Hard Drive in DRC8030N
Yes you can replace the hard drive with a larger one. I have a 500 gig hard drive in mine. You can do the same thing with the DVD drive.
Any more problems, contact me at bigsteve1962@excite.com
Feb 26, 2009 | RCA DRC8030N
Finalized disk won't play in other players
You might check your burner to see if it is working correctly. If you are using the same media and it worked before, perhaps the burner or the burning software is not working correctly.
Jan 17, 2009 | RCA DRC8030N
Programing my drc8030n remote to the tv
Try looking! Here, for example:
http://remotefinder.rca.com/default.aspx?site=rca
or http://www.thompsontv.com/rcarc.html
Sep 30, 2008 | RCA DRC8030N
RCA DRC8030N
Hi. I recenlty fixed a unit with the same problem and I had to replace the motherboard. I could not get the remote to do a darn thing and the front pannel buttons would not do a thing either. Before going to the extreme, and if you still have functionality via the front pannel buttons, try to reset/format the unit. Keep in mind that this will erase everything on the hard drive. While in the main menu and with no DVD disk inside, press and hold the play and open buttons for about 7 seconds until you get the FORMAT message on the LCD. If this does nothing to leviate your problem, then replacing parts will be needed. I do have plenty of mother boards and hard drives left and would not mind selling them. Thanks.
Aug 20, 2008 | RCA DRC8030N
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
RCA DVR SAYS HELLO
Did you try pressing the power button?
May 16, 2008 | RCA DRC8030N
RCA DRC8030N
These units have flaky TV tuners. Try connecting the coax cable (the one with the cable television signal or antena) to the back of your TV first and from there take the output to the input of the DVR. By doing this, you will beusing your TVs TV tuner vs the DVR's flaky one.
Mar 13, 2008 | RCA DRC8030N
RCA DRC8030N Logo
260 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
