Question about Microsoft Xbox 360 Console
No display signal thru tv
I've only had my xbox 360 since Feb 08. It has been treated with kid gloves. When I turn the unit on all looks normal. The only picture I get on my TV are small dots and lines. I thought maybe the cable was bad, however my friend brought the cable from his 360 and the problem was the same. Yes, we checked the HD switch on the cable. Any help would be appreciated. Thanks in advance. Sean
  • 4 more comments
  • philmolloy Nov 09, 2008
    i have the same problem as sean 11"sh
  • Anonymous Nov 09, 2008
    I have the same problem and yes there is sound.
  • slow_type Nov 09, 2008
    I have the same problem.
    First the picture went weird with the colours then after restarting the xbox the picutre went completly. I have sound still but no picture :(
  • Anonymous Nov 10, 2008
    i have the same issue has you guys... help plz
    i have the same problem some help plz
  • Anonymous Dec 25, 2008
    Same problem, whats going wrong?
Any sound from the system?
Posted on Nov 09, 2008
Proscan tv
Check that you're on the correct input and the Xbox 360 is sending the correct signal (be it 720 or 1080).
Sep 08, 2014 | Proscan Televison & Video
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
Update failed?? cannot find you xbox 360 hard
You must have a memory card or harddrive plugged into the Xbox 360 for the update. Please note that the update might not fit on the memory card
Apr 19, 2010 | Microsoft Xbox 360 Console
I am getting no picture on my xbox 360 when its connected thru the HDMi cable.
first make sure your tv is on the right setting to display the picture usually hdm1/hdm2 in this does not help take the game out of the console turn it off then turn it back on with the guide button on the joypad and hold the right trigger and y this will reset the display settings on your console if this fail try www.xbox.com/support/contact
Jun 14, 2009 | Microsoft Xbox 360 Console
No signal from xbox to tv
Try resetting resolution and then tweakin sound setting in menu.
Look Here: http://cocaman.ch/wp/2006/12/reset-xbox360-resolution/
Jan 10, 2009 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Light and dark
hi there, you have a hardware prob. , try the inverter of the lcd, replace it and test it. ty
Feb 16, 2008 | Olevia LT37HVS 37 in. LCD HDTV
YPbPr inputs not working
Tacz, What video input# on the back of the TV is your component video?? Are you sure the TV is set to look at that video input#??? You may be looking at one of the composite video inputs as far as the TV is concerned and with nothing plugged in to that input the TV would naturally give the error message you indicated. Let me know.. Bill
Jun 11, 2007 | RCA 27F530T 27" TV
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
