Question about Fahrenheat PHH15002 Oil Filled Baseboard Heater
Smells like burn't plastic.
My heater was smelling , I could smell it mainly around thermostat knob and it was hot to touch on the back beside of thermostat knob.
Thanks msrob
  • 1 more comment
  • gwisniewski Nov 11, 2008
    When the heater gets warm it smells of burnt plastic. The smell seems to be coming from around the thermostat. This unit is only a year old.
  • wilee1 Nov 15, 2008
    I am having the same issue. Smells of burnt plastic at the thermostat knob, and it's only one year old. I plan on calling the manufacturer Monday AM.
  • Mike Robertson
    Mike Robertson Feb 23, 2009
    Diode fixed the problem, great answer.
This is for the LFP6152E electric heater. I called tech support (800.642.HEAT), and explained the problem. I was told it was a diode that went bad, and they're sending me a repair kit. I guess I'll keep this number handy for the next few years.
Posted on Nov 17, 2008
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Why does the heater smell and not get hot enough?
The smell is dirt or dust on heating element. If not hot enough it is because the thermostat may be prematurely shutting down.
Nov 22, 2015 | Heating & Cooling
I just bought a new Samsung fridge and the side are hot and it also smells like burning plastic is there any problem?please help
The sides are hot probably due to the operation of the moisture control system heaters. These heaters operate to prevent moisture accumulation on the box due to humid air in the space where the unit is located. If you live in a cooler climate, you may not need for these heaters to operate. Not sure about the burning plastic smell.
Apr 19, 2015 | Samsung Refrigerators
Dryer smells like it's burning
You probably have lint build up in the lint houing, you need to clean dryer by take dryer apart ,you may need to call services tech.
Feb 18, 2015 | Whirlpool Dryers
Hot water heater thermostat
Copy following link for service manual and to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Add a comment and say if this is new heater or older heater that stopped working, and include brand for best guesses at the solution.
Gene
Jul 22, 2013 | Water Heaters
Engine died burning smell
If the smell is like burning oil or really hot coolant. you may have killed the motor. If it smells like burning plastic ,look for shorthing wires around the exhaust manifold battery, alternator or place that a wire could be burnt. If a rubber smell check for belt failure.
Jan 19, 2013 | Toyota 4Runner Cars & Trucks
Heater of car smells
A mouse or leaves from a nearby tree have gotten into the AC/Heater blower motor and they are touching the blower motor speed control resistor, this is very hot and makes them smolder and smoke and smell. You will need to remove the blower motor from the housing that it is in and clean out what ever is in there.
Jul 19, 2012 | 1997 Hyundai Sonata
LEW0050PQ dryer works but smells like burning
In many machines, those elements, which are manufactured by "robots", are very cheaply made.
Rather than risk a fire, perhaps an investment of 20 - 30 dollars for a new element might be a good idea.
If you decide to do this, take a second look around for what specifically is getting so hot it is melting.
Likely the loose wire inside the element is doing that problem.
I should guess it is out of it's place and is melting an adjacent wire outside the heating element.
God bless your efforts.
Oct 05, 2017 | Whirlpool GEW9250 Electric Dryer
2001 aurora when fan is on high for a period of time it smells like the header is burning.
Not sure what a burning header smells like, but I would expect two possible smells. First, if the blower motor itself is going, you might smell the windings getting hot - like a transformer burning. If this were the case I would expect that the motor wouldn't spin on the low speeds.
The other smell you sometimes get is when the heater core leaks. Then you will get a coolant smell inside the car and sometimes (usually) a wet carpet as well.
Feb 22, 2011 | 2002 Oldsmobile Aurora
The dryer is hot to the touch inside the drum
two issues the heat thermal relay or the fan motor quit working you can go to www.appliancepros.com and look up the parts list for your model.
Apr 14, 2010 | Amana DLE330RAW Electric Dryer
Fahrenheat PHH15002 Oil Filled Baseboard Heater Logo
930 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
