Question about KitchenAid Cooktops
Kitchenaid Gas Cooktop with electronic ignition
This is a weird one.  Twice our cooktop (about 10 years old) has popped and flashed from a rear burner, tripping the circuit breaker.  One other burner was being used at the time.  The flash is so instantaneous that we haven't seen exactly where the flash originates.  We had an electrician look at the plugs, etc., after the first event, but he found nothing.  The second time it happened we decided it must be a problem with the cooktop unit.  Any guesses?
    President:
  • KitchenAid Master
  • 2,651 Answers
You sound as if the short is occourring within the switch assy perhaps water has spilled on it, listed on gas range, but assuming you have an electric unit, with the knobs poking through the glass
Posted on Nov 09, 2008
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
My kitchenaid gas stove continues to try to ignite making popping sounds
Here You can see how to disassemble Kitchenaid cooktop. I replaced everything on this one, since I knew its a big job, decided to do everything at once. Problem is - cooktop is dead, no spark to any burner. I hope it helps! Thanks! How To Repair Whirlpool KitchenAid Stove Cooktop HD 1080
Apr 24, 2010 | KitchenAid 31 in. KGCS105 Gas Cooktop
Kitchenaid gas cooktop will not ignite.
check 1st i have a power or in plug the unit,if ok the power, nid to replace ther ignition coil but is expensive,use macth temporary if u use ur cooktop
tnx gerbee
Jun 27, 2009 | KitchenAid Architect KGCP484KSS Gas...
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Disassembling kitchenaid gas cooktop to replace the ignitor switch
heatman101
Jun 09, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Our cooktop will not turn on!!
Plug the power line press the reset button.
Jan 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Cooktops Logo
321 people viewed this question
Top KitchenAid Cooktops Experts
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
