Question about Microsoft Xbox 360 Console
Audio but no video
I have cleaned all the av cables, I have double checked and made sure they were all plugged in right, and the av cable is set for TV, so why am I not able to see picture but I can hear the sound?
  • 6 more comments
  • Anonymous Nov 10, 2008
    same
  • boxingstud06 Nov 11, 2008
    can hear the audio but see no picture.
    can hear sound but see no picture
  • Anonymous Nov 11, 2008
    i can hear the audio but there's just dots going across the screen
  • blueiz36575 Nov 11, 2008
    i have the same problem
  • pdizzle123 Nov 11, 2008
    i have checked all the av cords and used like 5 tvs but the xbox will just play the audio and not show the video
  • kth_jay Nov 14, 2008
    the green light is on the front and i can hear my xbox start up but no video, any solutions?
  • Anonymous Nov 16, 2008
    Anyone got a solution?
    Scholar:
  • 31 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazingdevice also has some more common problems like Audio but no videoproblem, disc read error etc. Microsoft is providing extended warrantyonly for red ring problem. Means you will have to spend some money toget this problem repaired also if you plan to send your xbox toMicrosoft, you will have to wait for 3-4 weeks to get back yourfavourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Feb 20, 2009
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
When ever i plug in my video and audio cable the red white and yellow ones, into the back of my Toshiba 26CV100U TV i don't get the picture i only get the sound what should i do ?
The Red, White and Yellow (AV) cable is for composite video and stereo audio. The yellow cable is the video part of this, the red and white are the audio --
3 possible solutions for you:
1. Make sure you match up the color of the plugs with the sockets on your tv.
2. Make sure you're not using the Red, Green, Blue (RGB) input on your tv which uses similar plugs, but has a different color coding.
3. Make sure your tv input is set to the AV input. This is often controlled by the "TV/Video" button on your remote, and the AV input is often called "Video 2" or "3" depending on the model.
Feb 28, 2011 | Toshiba Televison & Video
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
When i plug my dazzle in their is no picture only audio heres my setup: dazzle pluged in laptop other end of the dazzle i have 3 splitters in with both xbox cables and double sided av cables and then the...
HDMI Cables supply sound AND audio - there is no need to provide others. ie. if you have an HDMI OUT on the source, this should go into the dazzle and supply audio and video. If you try both it wont work. The AV cables from the xbox is to provide a source to an external audio amplifier/speaker system.
Have a look at this on Youtube, there are loads of set up videos.
http://www.youtube.com/watch?v=iO6rFmE7GQY
Regards :)
Dec 19, 2010 | Computers & Internet
Ok I have a xnox 360 and when i plug the color coded cables into the color coded tv inputs i turn the channal to video 2 and i hear sound but i could not see anything? sooo what do i do?
Are you using AV or component cables?
*Solution for AV Cable*
Check to make sure the cable is fully plugged into the port. Having it even just slightly out of the socket will render no video. If this doesn't work, try plugging it into a different port on your television to make sure the port isn't bad. If you still have no video - the video part of the cable could be bad and you might need a new cable.
Also make sure that if your cable has BOTH component and AV connections available that the switch at the end of the cable near the Xbox is set to "TV" as opposed to "HDTV"
*Solution for Component Cable*
Also check to make sure that all the video connections are fully plugged in. If even one of them isn't plugged in fully, it could render no video. Also make sure that you have them properly plugged in to the right color. If you're just quickly connecting it to the back of the TV without proper lighting, it can be easy to confuse the blue and green connections.
When using component, make sure that the switch at the end of the cable near the Xbox is set to "HDTV" as opposed to "TV".
Jul 09, 2010 | Microsoft Xbox 360 Console
DVD player Model AD-1000. No video using composite video (3 Py connections) but do get audio. Video and Audio work using component video
When using Component Video you MUST use AV for the Audio in ALL circumstances. Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 03, 2010 | Aspire Digital AD-1000 DVD Player
Av cable
Before plugging up any cables to your TV, look to make sure that you know the input number on the back of the tv if you have multiple inputs on your TV.
Make sure the video cable plugs into the video input on your tv, then the two audio cables, make sure they plug into the audio inputs on your tv and then make sure your tv is set to the right input and everything should be good, turn on the game system and enjoy.
Jul 31, 2009 | Sony Video Game Consoles & Games
Want to view my canon mvx330i camcorder through my tv
Open the front plastic cover to the right of the lens and expose the ports. The yellow one is the AV port. Press the MENU button on the left side and use the rocker switch above to display AV-PHONES, select AV, and press the MENU button to set it and close the menu. Turn both  the camcorder and TV OFF.
Connect the camcorder AV port to the TV RGB inputs (VIDEO + AUDIO L + AUDIO R) with the cable that came with the camcorder. It has a mini stereo plug at one end and three RCA plugs at the other.
Switch everything on, press PLAY on the camcorder (don't forget to make sure the cassette is wound back to the start). sit back and enjoy.
Dec 11, 2008 | Canon MVX330i Mini DV Digital Camcorder
DC doesn´t has image
try a different av cable or jiggle the connectro on the dreamcast av port
Apr 10, 2008 | Sega Dreamcast Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
