Question about La Crosse Radio Controlled Atomic Clock
Second Hand stopped on Atomic Clock
I have a sharp atomic wall clock and the second hand is stuck moving back in forth on same second without advancing. How can I make it go around the clock again.
How can I set the time?
Once you select the time zone and whether you are observing DST, the clock sets automatically. That's the point of having an atomic clock.
Apr 19, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
HI I live in Hawaii we dont go by pacific time zone like California how do I set my clock WT-3122A
Aloha. Try asking your question here: Clocks Watches Questions . They helped me before with an antique clock problem. Good Luck.
Oct 04, 2014 | La Crosse Technology WT-3122A 12.5" Wood...
Minute hand on atomic clock keeps moving
Take the battery out and put it back in the opposite direction. Wait 5 seconds. Put it back in the correct position. The minute hand will go around very fast and eventually come to a stop. This can take a couple days. That means it is waiting for a radio signal from Colorado. For a better signal, place the clock in a window that is facing Colorado. The minute hand will begin to spin very fast until it stops at the correct time. Again, this could take up to 2 days.
Sep 12, 2012 | Staples Round Atomic Wall Clock; 14
The second hand on our LaCrosse atomic clock has stopped moving but the clock continues to keep perfect time. How do we get the second hand turning again?
The manual for one of their clocks says the clock will change the second hand to two-second intervals to conserve energy when the battery voltage gets low. Perhaps your battery is VERY low.
Mar 25, 2011 | La Crosse Radio Controlled Atomic Clock
Atomic Clock by SkyScan model # 28600. Clock
It does that until it receives a signal. Leave it overnight and it will probably get one. Instructions for this clock are at
Apr 04, 2010 | SkyScan 86709 Atomic Wall Clock
My Barolo atomic wall clock (with hands) stopped working (I think the battery died). I replaced the battery, and now the hands just keep going around without stopping. I have removed & replaced the...
Try to move the clock to a different place. Atomic clocks work by receiving a radio signal. If it has no reception, it may do that. However, I would suspect that no reception would lead to it not setting at all(at least based on the ones I've seen) and it may be something wrong with it (i.e. having difficulty detecting where it's hands are) Good luck.
Jan 03, 2010 | Kitchen Appliances - Others
Time is behind 4 hours, wont start with new battery
I inserted new batteries, second hand would not move at all. 1 hour later I came back and clock was running with the correct time.
Jan 29, 2009 | La Crosse Radio Controlled Atomic Clock
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
I have a sharp 12 inch atomic clock...cant get it to reset and dont have instructions...please help
Oct 13, 2007 | Audio Players & Recorders
La Crosse Radio Controlled Atomic Clock Logo
1,095 people viewed this question
Top La Crosse Home Experts
Are you a La Crosse Home Expert? Answer questions, earn points and help others
