Question about Dell 926 All-In-One InkJet Printer
Printing alignment I replaced the color cartridge and now it keeps telling me that there is alignment problems and to remove the tape which I did. I pulled out the power brick and that didn't work. I uninstalled and reinstalled the printer and that didn't work. Help--I didn't have problems until I replaced the color cartridge.
  • 2 more comments
  • blkwid1 Nov 25, 2008
    My printer keeps flashing error 1203 at me and i ve done everything theve told me to do.
  • Anonymous Jan 13, 2009
    I changed both the black ink and color ink cartridges, and the printer tells me that there is an alignment problem and to remove the tape. There was no tape on the cartridges.
  • hampday Jan 23, 2009
    Ordered a new color cartridge (from Dell) for the Lexmark AIO 926 and installed it, but the printer displayed an "Install new cartridge" message or tells me to remove the tape strip (which I also did). A local cartridge filler cleaned the cartridge and told me its ink reservoir was full. My PC display shows a "?" over the color cartridge picture and the printer prints only black type.
    Submitted by Hampday, 1/23/09 E-mail: Hampday1@verizon.net
  • Anonymous Jan 24, 2009
    i replaced the color cartridge and it still says error and to replace. I cleaned with the alcohol and it still don't work.
I have a 926 Dell All In One Ink Jet Printer. I am having an issue where only certain items are printing. For example I can submit a word document and maybe the first two lines will print then nothing else will print. But on my Print Preveiw screen it is showing that everything should be printing. I thought it might be just that document but I have tired printing off the web, Excel, Emails and I have the same issues. I have uninstalled the printer and reinstalled it. I went to Dell support and downloaded any upgrades or patches. So I have not clue what to do next. Can someone help. Thanks
Posted on Dec 01, 2008
    Novelist:
  • 148 Answers
Greetings my name is mark and I will be glad to assist you. HP printers like a lot of HP products are designed to be proprietary even right down to the ink they put in. Did you replace the cartridge with a factory cartridge if not that is your problem if so take a soft cloth with "denatured" alcohol and clean the points on the cartridge and in the printer. the reason for the denatured alcohol is regular rubbing alcohol contains 80% water and may damage the contacts. Let me know if this worked if not we will try another solution.
Be mucho blessed,
Mark
Posted on Nov 14, 2008
I don't know how to install the cartridgre on my new printer J 3680 Could you please tell me how? Thanks,
Follow the instructions below to install the print cartridges for the first time. Installing print cartridges Step one: Install the print cartridges Follow these steps to install the cartridges.
  1. Open the cartridge door. The carriage moves to the far right side of the product. Figure 1: Open the cartridge doorc01133347.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch onlythe black plastic, gently remove the plastic tape by using the pink pull tab. Figure 2: Remove tape from cartridgec01107115.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections.Do not remove the copper strips. They are required electrical contacts. Figure 3: Do not touch the ink nozzles or copper contacts.c01107116.jpg
  3. Slide each new cartridge forward into the empty slot. Then gently push theupper part of the cartridge forward until it clicks into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black cartridge into the right slot.
    Figure 4: Insert the cartridgec01107117.jpg
  4. Close the cartridge door.
Step two: : Align the print cartridge The product prompts you to align cartridges every time you install a cartridge. You can also align the cartridges at any time from the control panel, or byusing the software you install with the product. Aligning the cartridgesensures high quality output.
  1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
  2. Press OK. The product prints an alignment page.
  3. Place the alignment page print-side down on the scanner glass.
  4. Press OK to scan the alignment page. When the scan finishes, the alignment is complete.
NOTE: If you have colored paper loaded in the input tray when you align the cartridges, the alignment will fail. Load unused plain white paper into the inputtray, and then try the alignment again.
Sep 13, 2010 | Office Equipment & Supplies
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
My printer says printing alignment and prints out a page, then says alignment problem remove tape from cartridge or look in troubeshooting guide
For alignment complete you need both print cartridges printing all colors.If you have empty cartridge or clogged cartridge alignment will not complete.Look which color missing and replace cartridge.
Nov 15, 2009 | Dell 962 Photo All-In-One InkJet Printer
Tops and bottoms of letters are cut off. I have changed the ink cartridge
Replace the old ink cartridge.
Verify that the unit is on. The On button is lit when the unit is on. If the device is not on, press the button to turn on the unit. Open the print cartridge door. The print carriage moves to the far right side of the unit. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. When replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. When replacing the black or photo print cartridge, remove the print cartridge from the slot on the right. Pull the print cartridge toward you and out of its slot. If the print cartridge is being removed because it is low or out of ink, recycle the print cartridge. Remove the new print cartridge from its packaging. Remove the plastic tape by using the pink pull tab. Removing the Tape from the catridge.
  1. Will have Copper-colored contacts.
  2. Plastic tape with pink pull tab ( must be removed before installing ).
  3. Ink nozzles under tape
  4. The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  5. Top & Bottom not printing properly.
  6. Load unused, plain, white letter, A4, or legal paper into the input tray
  7. If coloured paper is loaded in the Input tray when the print catridges are aligned, the alignment will fail. Load unused, plain white paper into the input tray when the Printer catridges are aligned, the alignment will fail. Load and unused plain white paper into the Input Tray and then try the alignment again.
    1. Press 6 to select Tools .
    2. Press 2 to select Align Print Cartridge The unit prints a print cartridge alignment sheet.
    3. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK. Now the printer will print properly.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Test page printing at the time of printer powered on
s.gif Solution minimtop.gif The product aligns the print cartridges every time that print cartridges are installed or replaced to ensure the highest-quality prints. The alignment page will continue to print every time that the product is turned on or off until the alignment process is completed. NOTE: If you remove and install the same print cartridge, the unit will NOT align the print cartridges. The unit remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. Follow the steps below, in the order presented, to correctly complete a print cartridge alignment. s.gif Step one: Remove the print cartridges minimtop.gif
  1. If the On/Resume button is not lit, press the On/Resume button to turn the product on. Figure 1: Press the On/Resume button to turn the product on c00316907.gif
  2. Make sure the paper tray is down and there is letter or A4 unused plain white paper loaded in the paper tray.
  3. Lower the access door until it stops. Figure 2: Lower the access door c00316908.gif Make sure the print carriage moves to the center. Figure 3: Print carriage in the center of the printer c00316909.gif
  4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it. Figure 4: The print carriage c00316910.gif
    • If replacing the black print cartridge, remove the print cartridge from the slot on the right.
    Figure 5: The print cartridges in the proper position c00316912.gif 1 - Tri-color print cartridge 2 - Black print cartridge
  5. Pull the print cartridge toward you out of its slot.
s.gif Step two: Install the new print cartridge minimtop.gif
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward at a slight upward angle into the empty slot. Using your index finger, push the print cartridge forward until it clicks into place. Figure 7: Insert the print cartridge c00316911.gif
  3. Close the access door.
s.gif Step three: Align the print cartridges minimtop.gif If you are installing a new print cartridge, the product begins to print a print cartridge alignment sheet. This may take a few minutes.
  1. Lift the lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass. Figure 8: Place the alignment page face down c00316913.gif
  3. Close the lid.
  4. Press the Scan button.
  5. The On/Resume light will blink during the alignment process.
  6. After the On/Resume light stops blinking, alignment is complete.
Feb 26, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
Aug 20, 2008 | Dell 926 All-In-One InkJet Printer
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
Alignment problem
Try swabbing the print surface of the color cartridge with a q-tip and a little alcohol. It may be clogged.
Nov 23, 2006 | Lexmark X6170 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
150 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
