Question about Denon AVR-1600 Receiver
Denon DRA 335R changes from tuner to phono by itself or turns off by itself
I have removed the batteries from the remote control and no change.
  • pagedouglas Nov 11, 2008
    I tried this and am waiting for the results as the problem is very sporatic and unpredictable. I don't have alot of faith in the solution as the unit is plugged into a switchable outlet that occationally get turned off anyway. But I appreciate the response.
  • 1,512 Answers
Hi
One thing that may help you with the problem is to power the amp right down by disconnecting from the wall socket, and then power up again 30 mins later. This will allow for a complete reset of the microprocessor stages of the unit. Try this and let me know how you get on. If the problem does not go away, happy to talk to you more about it.
regards
robotek
Posted on Nov 09, 2008
  • Graeme Ross
    Graeme Ross Nov 12, 2008
    ok, initially it just sounded a lot like a corrupted program counter to the firmware controlling front panel operations, If it always switches to phono when the problem occurs, what happens with audio, and can you just reselect tuner after the problem occurs.
    Sometimes this condition can be caused by a collapsed tact switch for the source being ghost selected. Or broken plastic button press assemblies to the front escutcheon. . Usually these problems can be ascertained by the "feel" of the button.
    If the unit actually locks out to the phono input, and wont allow you to select anything else, it can relate to a faulty reset device to the front panel processor, or even a hair line fracture to the front panel PCB. Attempting to get the unit to fault with external stimulus is the approach to take on the bench to fix it. Things like mechanical tapping, application of heat and cooling, this sort of approach. I have also seen some units that use a serial bus to control input stage switching IC's where the input IC's can be damaged(intermittently switching) by a static discharge from connecting switch mode power supply equipment like TV, video, and VCR's. They can out of the blue change sources, although the front panel indication often stays, just the audio switches.
    Can you let me know a little more about the circumstances surrounding the occurrence of the problem.
    cheers
    regards
    robotek
Do you have the TV remote codes for Denon DR 335R
Which TV are you wanting to control as there are hundreds of codes
Dec 30, 2016 | Denon Audio Players & Recorders
Can dra 37 be used as a pre-amp without connecting speakers
If you mean a sa control center for source selection, volume and tone control, yes, but NOT for a turntable (no PHONO).
Controlled audio goes emerges from the pre-out. Page 9.
http://www.retrevo.com/support/Denon-DRA-37-Receivers-manual/id/696dj086/t/2/
But you could still use its own speaker terminals if your exxternal amp has is remote or has its own volume control to match it up with other speakers.
Sep 05, 2011 | Denon DRA-37
Is the denon dra-395 compatible with an ipod?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 13, 2011 | Denon DRA-395 Receiver
Loud distortion through phono inputs
Phono inputs are designed for turntables only. Any other device will provide too high a signal for that input to handle. The phono input has an extra amplification stage built in. The distortion is because of the high suignal level being supplied to the input. The only way to get this to work properly is to purchase an antenuator which will decrease the signal level to the phono level.
Dan
Dec 18, 2009 | Denon Audio Players & Recorders
I have a Denon DRA-397 Receiver. It was stuck with the "Panel Lock" but I followed the instructions here to hold the "B" and "Mode" buttons while powering on. It unlocked the panel. Now the Reciever is...
Check for a reset of the receiver. If no mention in manual you might want to check with the manufacturer for a code . If nada then the electronics are fubar and you are SOL.
Aug 31, 2017 | Denon DRA-397
Denon DRA-335R turns off or changes the source or radio station
I have the exact same problem with my Denon 1600 receiver. I bought the receiver 3 weeks ago and I've been trying to solve this problem ever since. The guys in the "Magnolia" room at Best Buy said it might be a defective receiver, or maybe the receiver is not compatible with my Brighthouse cable box. I think I might swap out the receiver this weekend to see if that solves the problem.
Sep 26, 2009 | Denon AVR-1600 Receiver
No Power
There is a thermal fuse built into the main transformer. It is possible that the fuse is open.
Dan
Mar 30, 2009 | Denon DRA-365R Receiver
Denon DRA 395 volume creeps to max by itself
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
Oct 01, 2007 | Audio Players & Recorders
Denon AVR-1600 Receiver Logo
966 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
