Question about Zanussi FLE1416W Front Load Washer
Problem with washing machine
Washing machine was either turned off during cycle or just stopped functioning, i released the door catch to open and empty. now all that happens when trying to restart is the lights come on the start button flashes but when pressed the door catch clicks about ten times and then stops and the lights go off.
  • Anonymous Mar 15, 2014
    Doors catch clicking but the machine runs and completes wash
  • Anonymous Mar 17, 2014
    Pressed pause button on washing machine and now cannot open door
  • 19 Answers
New door sensor im afraid,unless the machine senses that the door is properly shut none of your wash or spin cycles will start.Sensor located inside washer casing , where lock pin on door handle enters machine.It may just be loose,try tightening the two screws either side of lock keep.If it needs replacing you will need to UNPLUG washer ,remove lid and slide your arm down inside front of washer to access.Good luck.
Posted on Aug 23, 2007
How do i open the door
You don't give the reason for your question.
The door catch generally has an electric lock to prevent the door being opened during a cycle. When the machine has finished it's programme or sometimes is switched off (check in the instruction manual) the lock remains engaged for about a minute and then the door will open.
If the door catch or lock develops a fault the machine top will have to be removed and the lock released manually.
Jun 28, 2016 | Washing Machines
Aeg protex how to open door mid cycle
To open door during mid cycle, turn off washer by plug and wait a couple of minutes until you hear a click, then the lock light ( assuming it has one ) will release, but make sure there is no water in the tub before opening the door. If possible when door is unlocked, run the drain setting and let the water pump out before hand. Hope this helps.
Aug 16, 2014 | AEG Washing Machines
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
I was using the spin cycle to spin water from a scarf. I decided to stop the stop so I hit cancel button. Now the washer door is locked and I can't open it.
• If the cycle is interrupted during spin, it will take approximately 2-3 minutes for the door lock to release. DO NOT force open the door. • To stop the washer, press Cancel.
Jan 05, 2011 | Frigidaire Affinity ATF7000E Front Load...
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jul 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
How do I stop cycle and unlock door?
Thank you !!
Jun 27, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Dead in the water
End of cycle? After the end of cycle you have to wait for 2 minutes minimum (or hear a click), only then you have to try the door; or your door won't open & if you force it you'll damage the door mechanism (not good). End of cycle means "your wash is done".
Pl rate if helped.
May 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door opens
faulty catch or switch interlock
Oct 18, 2007 | Maytag Neptune MAH6500A Front Load Washer
Zanussi FLE1416W Front Load Washer Logo
482 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
