Question about Kodak EASYSHARE 5100 All-In-One Printer
Can't get picture to scan
We have a kodak 5300 printer and can not scan pitures to the computer. We have a dell windows Vista. It is a brand new computer. We are able to print and make copies it is just the scanning we are havinga an issue with.
  • Anonymous Dec 02, 2008
    I have a kodak ESP 3 I am unable to scan
I have a kodak easyshare esp3 all in one. I have tried several times to install the software, I have done the clear utility several times and tried again, no luck, I have disabled anti virus software and firewall and still nothing. The problem is i get about 2/3 of the way through and get an error message saying the installation can't continue, Any solutions?
Posted on Mar 22, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 214 Answers
Try doing this procedure to fix the issue.....
To perform a clean installation of the KODAK AiO Home Center software, follow the instructions below:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the KODAK All-in-One Printer Software:
    a. In the Control Panel, select Add or Remove Programs (WINDOWS XP Operating Systems) or Program and Features (WINDOWS VISTA Operating Systems).
    b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
      • Kodak EasyShare software
      • KODAK All-in-One Printer Software
      • Kodak EasyShare 5000 series all-in-one software
    c. Click Change or Remove (WINDOWS XP OS) or Uninstall (WINDOWS VISTA OS).
    d. When the Install Wizard appears, click Next.
    e. Depending on the issue(s) you are experiencing, do the following:
      • If you are experiencing errors with KODAK EASYSHARE Software, such as a tri-code, in addition to errors with KODAK All-in-One Printer Home Center Software, select Remove, click Next, and follow the on-screen instructions for removing the software.
      • If you are not experiencing errors with KODAK EASYSHARE Software, select Modify to uninstall only KODAK All-in-One Printer Home Center Software, then click Next.
    f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
    g. In the Ready to remove the program window, click Next.
    h. In the Uninstall Complete window, click Continue.
    i. Restart the computer.
IMPORTANT:
    • If you selected Modify and only uninstalled the KODAK All-in-One Printer Software and did not uninstall the KODAK EASYSHARE Software, continue to Step 4.
    • If you selected Remove and uninstalled both the KODAK All-in-One Printer Software and KODAK EASYSHARE Software, continue with Step 3.
3. Run the Clear Utility to delete any previously installed KODAK All-in-One Printer Software components:
    1. Got to www.kodak.com/go/clear to download the Clear Utility for KODAK EASYSHARE Software.
    2. Select your operating system from the drop-down list and click the Download button to save the file to your desktop.
      Note: If the status indicator on the Clear Utility stops, check the taskbar on your computer for an active security program. If a security program appears in the taskbar, it may be prohibiting the Clear Utility from running. You must allow the Clear Utility to run on your computer before you can continue.
4. Delete the files and folders that can interfere with the installation.
    For WINDOWS XP OS, delete:
      • Printer folder in C:\Program Files\Kodak
      • Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
      • Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
      • Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
    For WINDOWS VISTA OS, delete:
      • Eastman Kodak Company folder in C:\ProgramData
      • Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
5. Run Disk Cleanup:
    1. Open My Computer.
    2. Right-click Local Disk (C:) and select Properties.
    3. Click the Disk Cleanup button.
    4. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
    5. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
    6. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
6. Shut down all background applications.
    1. Select Start > Run.
    2. Type msconfig in the Open field, and click OK.
    3. Select the Startup tab.
      IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
    4. Click Disable All , then click OK .
    5. When prompted, restart the computer.
7. After the computer restarts, install the latest version of the KODAK All-in-One Printer Software as a free download from the Kodak Web site at www.kodak.com/go/downloads.
    • If the customer has the latest version of the KODAK All-in-One Printer Software on CD, install the software from the CD.
8. Before restarting the computer again, turn on the background applications.
    2. Type msconfig in the Open field and click OK.
    4. Under Startup Items:
      - If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
      - If all background items were originally selected, click Enable All, and click OK.
9. Restart the computer.
Posted on Nov 09, 2008
I gota dell windows 7 computer when i try to scan with my aio 5300 easy share a window pups up that reads .. YOU NEED A WIA DRIVER TO RUN THIS DIVICE
Did you install the Kodak software before connecting the printer to the computer? http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true has the software for Windows.
This error usually means that you installed the generic driver from the OS which only runs printer. Uninstall the current driver, disconnect the data cable (USB) and then restart your computer. Install the software from the Kodak site above. Then connect the data cable when prompted to do so. Try scanning after completing the installation procedure.
If you did install the Kodak software, it may have gotten corrupted. Please follow the above directions and let me know if you have any problems.
I hope this helps.
Mar 26, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I think im missing the driver for the scanner part of my 5300 kodak all in one, it wont comunicate with the computer dj icant scan a picture to the computer from the printer
Go to: http://support.en.kodak.com/app/answers/detail/a_id/32108/selected/true
Download the software for your Printer
Installation Instructions
  1. Verify that your computer meets the system requirements. note.gif WINDOWS XP Operating System, 64-bit, is not supported.
  2. Disconnect your all-in-one printer from your computer.
  3. Verify that you logged on to the computer using the administrator account.
  4. Close all programs.
  5. Download the software onto your computer.
  6. Double-click the *.exe file, then follow the on-screen instructions.
  7. When the installation is complete, connect your all-in-one printer to your computer.
  8. Select Start > Programs > Kodak > Kodak AiO Home Center.
Mar 05, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
My printer is not printing with all of the colors and there is banding, brand new ink and printheads changed in the last 6 months.
I'm having a simialr problem, I can get my Kodak EasyShare 5300 printer to print pictures just fine, I can even get it to copy & print from the scanner. In both black and color inks. What I can not get the Kodak EasyShare 5300 Printer to do is to print from Microsoft Office Word, or Works for that matter any text document what so ever. I've never had a problem with the printer ever, not even when I upgraded to Windows 7 it printed just fine up till a few months ago and started acting up. At first I thought it was because I hadn't used it in awhile so I replaced both cartridges so they are brand new. Tried my experiment again and it did the same thing, pictures, and copy and print from the printer works just great...text however from the Word programs....nothing but a blank page.
Running Windows 7 - 64 bit Dell Touchscreen, Dual Core Processor. Before you ask...before this incident the Kodak Printer intergraded just fine and worked without incident. Since it is not the printer portion (unless its the printhead), it has to be a software problem...although, I used the disk that came with the printer to re-install it and not from the web just in case that was the problem. Course would installing the web upgraded software be of any assistance? Anyone have any solutions? Thanks.
Jun 16, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Will not let me install new printer ESP-5 CD
Kodak printer ESP-5 CD version 3.2 is not compatible with Vista. You will need to upgrade to Firmware 4.3 Windows XP/Vista from Kodak Printers. The drivers may be found here:
http://www.opendrivers.com/freedownload/280436/kodak-esp-5-all-in-one-printer-firmware-4.3-windows-xp-vista-download.html
Jul 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak easy share 5300 all in one printer will not scan
are getting any error msg like 1-2036 or anyother and are you using Vista or Xp,,,,try using the windows fax and scan settings....let me know and i will try and help you
Apr 04, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I cannot scan on my easyshare 5300 It only scans halfway and then freezes. We have Windows Vista. Is that the problem?
NO . It should not be a VISTA problem as it has a VISTA driver available. Have you tried reinstalling the software and driver?
Kodak support page for your model: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10586&pq-locale=en_US&_requestid=2077
Feb 22, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How to scan pictures into file
Download the user manual for your Kodak 5300 from HERE. That should help you.
May 17, 2008 | Kodak 5300 All-in-One InkJet Printer
Can't scan with Kodak Easyshare 5300 printer
My Scanner (Barely used, not even through the first set of ink cartridges yet) was working beatifully. Then all of the sudden the same thing happened to mine...blinking lights...Power light flashing Yellow...I contacted Kodak and they had me do the same old thing...Unplug, uninstall, reinstall, restart. Nothing works...They also try and have you redownload firmware (But Hello....You cant if the printer isnt ON!) So I went back to them again to say none of it worked. They said its the print head and they are sending me another one. Ive read a lot of terrible reviews of this printer just because of the crappy print head...You would think they could fix that by now, or have 5 extras in the package when you buy it.
Feb 27, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
223 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
