Question about Dryers
How do I open up my Kenmore 60 Series Gas Dryer 97566200
The heat has gone out on my Kenmore 60 Series Soft Heat Large Capacity Gas Dryer. It is model #9756200. I have read a few trouble-shooting ideas, but I do not know how to remove the panel at the front. I know it is the front, bottom panel that is supposed to come off, but I am not sure how. I don't want to break the panel on top of all my other problems!! lol. Any help??
Best wishes,
Kristin
    President:
  • Dryers Master
  • 2,651 Answers
If htere is a bottom acess panel, its usually about 12-14 inches high and is held on with pressure clips, simply inset a putty knife and they should release
Posted on Nov 09, 2008
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Dryer wont heat. cleaned exhaust duct still problem exsists. Model 60 series kenmore gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 600 6965 Electric Dryer
My Kenmore 60 Series Extra Capacity dryer is not heating.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 25, 2011 | Kenmore 800 7983 Dryer
My Kenmore 60 series gas dryer will not heat up. I checked the lint trap and it is clean. How do I open the front panel to check the pilot light?
Some dryers have a small inspection hole covered by a small platic cap.
Remove cap and look inside unit for pilot. Newer dryers have an igniter that glows when the dryer is turned on. It ignites the gas then goes out.
Jul 30, 2009 | Kenmore 73952 Gas Dryer
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Manual for a Kenmoore 60 series soft heat large capacity dryer.
Here is the website for Kenmore driers and the manuals to download for free in Adobe format. They are only listed by model number.
http://www.kenmore.com/shc/s/search_10154_12604?vName=Kenmore&cName=Washers+%26+Dryers&keyword=kenmore+drier&sLevel=0
Dec 22, 2008 | Kenmore 63942 Dryer
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
i need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
Feb 23, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
525 people viewed this question
Top Dryers Experts
