Question about Samsung SP-R4232 42 in. Plasma HDTV
HDTV TRYING TO FIGURE OUT WHY ALL THE HD CHANNELS COME ON THE TV IN REDUCED SCREEN SIZE. ANY ANSWERS?
    Scholar:
  • 118 Answers
Usually they can do that, like the sides will come in a little bit. I have HD on my 50 inch plasma Samsung, and we have Time Warner Cable, but not all of our channels are like that. If all of them are like that for you, then you should go to your menu and settings to look for zoom. But if they all aren't like that and only some, then that's how the channels are.
Posted on Jan 30, 2009
Screen seems stretched. How do I fix it?
60'' Vizio TV screen is stretched in 'normal' screen mode on HD ...
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
TV Problem: The picture on my television is stretched out on the ...
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
How to Fix the Most Annoying Features of Your New HDTV ...
Dec 31, 2015 | Vizio VA Televison & Video
The aspect ratio on the HD channels are full screen - which is correct. However all other channels have the incorrect aspect ratio. (reduced size) A solution please???
Many times HD channels will come in more clear, but with a smaller picture or widescreen view. There should be a button on your remote called 'wide' or 'zoom' and it will let you adjust the size on the fly. If you adjust the view while watching an HD channel, and you switch to a standard channel, you will have to change the ratio back. For other information and help with LG TVS visit http://www.lg.com/us/support. Thanks
Mar 31, 2011 | LG 42SL9000 42 in. HD-Ready LED TV
On Sony 36 iinch Trinitron TV, when I go to HDTV channels the picture size changes to widescreen. How do I adjust back to full screen on HD? I tried the "no zoom" button but that doesn't work. Cannot...
Please note that all HDTV channels project wide screen pictures. You can still go to settings and then picture mode and change the format to 4:3/full mode.
Aug 28, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I am getting a blue screen that says mode not supported when I try to view HD channels
This usually indicates that you are trying to watch a screen in a higher resolution than the Tv will actually handle
Aug 17, 2009 | Televison & Video
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Horizontal Black Bars on HD channels?
You can change aspect ratio by remote. I hope it will be solve
Apr 02, 2017 | Dell W4201C 42 in. Plasma HDTV
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Size of screen
If you have black panel os sides the picture is not HD. Not allways the HD broadcasting have HD shows. The advertising for example is not HD. Check the picture size in the tv to be "allonged" and play with the screen size with your cable box remote. Usually is # button.
From what I know LC42D62U has no TV Guide feature.
Dec 06, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Screen Size
When you are using the DVI connection on this unit it will automatically set the aspect ratio. There is no way to force it into stretching the picture as it will with other input sources. The only way to get to fullscreen would be to go into the setup menu on your cable box and set the "4:3 override" option to one that will meet your satisfaction. I'm having issues with this one skewing the picture to the left on DVI input. I'll crack it open one of these days to see if there are some adjustments that I can mess with on the inside. If there is anything further I figure out, I'll repost.
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung SP-R4232 42 in. Plasma HDTV Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
