Question about Refrigerators
GE Fridge Further to my Fridge problem, the motor is running more than usual, I have the control set to max and the Fridge should be colder and the ice is forming on the rear of the inside panel of the freezer, just a thin layer mainly on the lower part of the metal inside back metal panel
  • Anonymous Feb 08, 2009
    The food is really frozen and ice is foaming
    Scholar:
  • 112 Answers
Pull the back panel off of the freezer and see if the evaporator is frozen over solid. If it is, replace the defrost timer. If it isn't, you may have sealed system issues.
Posted on Nov 09, 2008
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
We did not receive a manual with our fridge and need to know what temperatures to set it at. It is a two door fridge with a bottom drawer freezer and digital settings. Can you helps? Also do you know how...
If you set both in the middle settings thats generally best. 1 is the on/off and compressor control to run the box temperature, the remaining will say colder /warmer, this can be misleading however as colder actually is colder freezer! not reefer box! so to max that one actually makes the reefer warmer and freezer colder!
Jan 12, 2011 | LG Refrigerators
Fridge not keeping cold whats the best temp. we only have no.s 1 to 10.
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 1005 reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
1 is the temperature thermostat, it actually controls the compresssor motors cycling,
thus box temperature as well, it often says 1-10 and off as well, the reamining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the refers box!
This is where the problems occur, when one notices the reefers box warm they max both settings,
which seems logical , and is for the thermostat dials setting.
Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!
Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!
not colder reefer! so you max or raise the thermostat, thats ok to do.
But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.
I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.
when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm too much in another day or so. But if the freezers making ice for days and never getting wet theres a airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it icedd up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?
setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons water.
Dec 27, 2010 | GE Profile PSI23NCR Side by Side...
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Freezer and fridge are getting warmer and warmer despite their settingsGE Profie PDS 20 MFS 2005
ONE OF THE MOST COMMON CAUSES FOR A SERVICE CALL IS EXACTLY WHAT YOU STATE, THE MAX SETTINGS ARE SET AND STILL ITS NOT GETTING COOLER, ESPECIALLY IN FRIDGE SECTION RIGHT?
IF YOU ARE MAKING ICE THATS DRY THE FREEZER IS OK,
THE PROBLEM 90% OF THE TIME IS THIS
AS THE FRIDGE SECTION IS RELIANT 100% UPON THE COLD AIR MIGRATING INTO THE FRIDGE COMPARTMENT VIA A LITTLE FLAPPER DOOR THAT OPENS OR CLOSES OR IN BETWEEN AS WELL , THUS ALLOWING MORE OR LESS AIR TO MIGRATE INTO THE REFRIGERATOR SIDE FROM THE FREEZER SIDE
THE STUPIDEST THING IS THE FRIDGE SAYS MAX COLD ON BOTH SETTINGS, ONE ACTUALLY CONTROLS THE COMPRESSOR AND DETERMINES HOW LONG THE COMPRESSOR WILL RUN IT USUALLY IS OFF AND 1-10 , THE ONE THAT TURNS OFF THE COMPRESSOR ISNT THE ONE THAT DETERMINES THE REFRIGERATORS TEMP! THE OTHER SETTING FOR COLDER FREEZER DOES!!!! TAKE THAT SETTING BACK OFF OF MAX FOR COLDER FREEZER AND THE LITTLE FLAPPER WILL OPEN ALL THE WAY , WHEN SET FOR MAX COLD THE FRIDGE SIDE STARVES!, ANY SETTING 1-10 SHOULD STILL KEEP THE FREEZER FREEZING AND MAKING ICE IS THE KEY! IF IT CAN THEN ITS NOT A REFRIGERATION PROBLEM , IT IS A CIRCULATION ISSUE
Aug 23, 2009 | GE Refrigerators
Freezer section is cold, but the refrigerator section is not
set to colder refrigerator ... not colder freezer!! the fridge is reliant upon air migrating into the area from freezer side! if you peg both controls to max , you get a warmer refrigerator , but colder freezer, the control that does not operate the compressor is the setting i mean, it usually says .. for coldest and everyone pegs it and its a common cause for a service call and people cant believe it, if you cant tell which is which set both to middle! evfen at warmest setting the freezer should still make ice and thats the test for freezers state1 can it make ice!
Aug 23, 2009 | Roper RT14DKX Top Freezer Refrigerator
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge seems to require max cold temp control
did you check to be sure the the compressor cooling fan is operational? if this is bad it will cause a problem similar to your condition. another thing if this checks ok is that your temp control could be getting weak, ( it has small springs connected to the contacts) and may need replacing. the fact that it will get to 0f tells me that compressor and freon system should be fine.
you mentioned the warm area on the side of your door is a anti moisture feature. if this area is abnormally hot it would indicate a bad condenser fan motor which is the compressor cooling fan.
If you have any further questions let me know thanks Peyton
Feb 23, 2009 | GE GSS20IETCC 20.0 Cu. Ft. Side-By-Side...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
