Question about Toshiba CZ32V51 32" TV
No pic, no sound
Toshiba CZ32V51 Manuf. Jul 99 I get no picture or sound, power light blinks. Checked all connections, but still not working. Is this an age-related thing, TV is over 6 years old? Fixable by a pro?
    Problem Solver:
  • 9 Answers
Power light blinking mean that the internal power supply is not working correctly. Often the internal power supply itself need to be repaired ( usually a one hour work if spare parts available). Another basic circuit in the TV can be short circuited due to a component failure and consequently cause the internal power supply to block everything. A routined pro must be able to tell you within short time cost of repair and spare parts. Up to you to then decide wether or not have this set repaired. Be aware a pro will ask you a fee for this service, even you don't want the set to be repaired.You can save some cost if you bring your TV set yourself to the repair-shop. The kind of problem is not really age-related; if your TV is running daily 16 hours, with many on/off switching, and particularly in a cool place can degrade some components within warranty time.
Posted on Nov 07, 2006
SOURCE:
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
The TV shut off by itself. Just before it went off, it said "timer off 0:00 press 09". Now when I push the power button the power light blinks and there is no picture.
sounds like somebody set the timer. normally this only makes the set enter standby mode and pressing the power button or a channel button usually wakes the set normally.
Just a longshot but have you tried pressing 09 while the light is blinking?
Mar 21, 2010 | Toshiba CZ32V51 32" TV
Intermittent picture. Lights on circuit blink when starting up. Often sound, no pic. Blue and blinking yellow for 2 or 3 tries, then picture. Sometimes only blue with no sound or pic. Ballast?
Ballast Board! Go to Encompass Parts Distr online find out what your Part# is! or Call 1-800-638-3328 also try UED 1-800-648-6657 This TV has alot of fuses over 20 of them!You didnt say have you replaced Lamp thats what goes first 9/10 unless you get power surge or Bad capacitors on the power supply Board caps are bad if they are puffed up on top 1000uf25v caps!
Nov 23, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Once the tv is on it only plays a few minutes, then the picture goes dark and the red power light on the front starts blinking. If I do nothing within five to ten minutes it would will come back on. then...
I had a similar problem, except I could make the screen and sound come back by banging on the the TV. I opened the TV and poked around on the circuit card and found a loose pin on one of the regulators, labeled C3852. I resoldered the pins and its working fine now.
Apr 04, 2009 | Toshiba CZ32V51 32" TV
Toshiba cz32v51power light flashes, with no picture
That means that an internal error had been detected, and now the TV is on protection mode.
To start unplug the power cord for ten minutes, and see if the TV restart.
If it does not try leaving the set unplugged for longer, let say two hours.
If still no luck call the number listed on the user manual, as the TV has an internal fault, and must be repaired by a technician.
Jan 14, 2009 | Toshiba CZ32V51 32" TV
Toshiba 32" cz32v51
is the 4" strip horizotal or vertical. Possible vertical i.c bad.
Feb 27, 2008 | Toshiba CZ32V51 32" TV
Still no picture, but there is sound
If you are getting static on screen you dont necessarily rule out the FBT, but if there is a fusible resistor by the FBT that is blowing it may be supplying current to the vert IC, the IC may be shorted internally or externally, check your connections and try replacing IC. Also check the pump up cap and if it is powered off the FBT the rectifier diode.
Jul 09, 2007 | Toshiba CZ32V51 32" TV
Set Randomly Turns off (Power LED Blinks) and Comes Back On ~1-2 minutes Later
if you have not gotten this fixed get it to a repair shop your problem is intermittent there might be lose solders or component in the power supply is failing and needs to be replaced.good luck blessing from belize
Jan 18, 2007 | Toshiba CZ32V51 32" TV
No pic, no sound
Hey Wilt: We had the same problem, for the same model of Toshiba TV. Had it repaired yesterday. Turns out the problem was the power supply (P.C.B). The total cost was $192.66 Canadian funds (taxes and labour all in). Our model was 6 years old, buts its playing like a brand new unit now. Hope this helped ...... Good luck
Oct 26, 2006 | Toshiba CZ32V51 32" TV
Toshiba CZ32V51 32" TV Logo
292 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
