More than likely it is set to to the wrong frequency. try and start the pc in safe mode and adjust the frequency to 60 hrtz. that should take care of it.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: COMPUTER WON'T WORK
I am assuming you have chosen power supply powerfull enough to handle all the power consuming hardware instaled in the PC. Please try unplug all connectors from the motherboard and plug them back again. Sometimes this solves the problem.
SOURCE: low profile video card for HP Slimline Desktop
Upgrading a certain parts in the computer depends on what purpose you want it to perform. If you're a GAMER or using imaging sofwares, then use MidRange Video Cards, like 7600GT. If the space on your Casing is very tight, then using low voltage Video cards like 7300LE.
SOURCE: HP Slimline s7310n...I had to do a new install of
Open up device manager> double click on the unknown device> go to the details tab> in the drop down choose hardware id> google the alpha numeric code on the first row before the & symbol (ex- PCI\VEN_14E4)
That will give you the make of the ethernet adapter you have on the pc. Once you have it installed you can patch up the wireless as it works on the network adaptor base which generates the ip address.
Hit me again if this dosent do the trick.
SOURCE: HP Pavilion Slimline s3122x powers up fan runs
Hi Im Rain.
I may have bad news for you. Its a very bad sign when your keyboard and monitor are not working at the same time. Sounds like the technician was right.
I also think its your motherboard. If you really just like the computer you can invest in another motherboard.
Testimonial: "Thanks so much. I appreciate your help. A new motherboard will probably cost more than a new pc. Thnaks for such a fast response."
