I just replaced the battery on my laptop and the lever seems to be stuck on the left. I cannot get it out. How do I safely remove the battery without damaging anything.
SOURCE: sound drivers for hp pavilion dv 6700
Go to HP's support site, download the autodetect program. Then the site will detect your machine profile and you can the download the sound drivers from a list provided for your machine.
SOURCE: My HP Pavilion dv6700 will not display anything.
Hello my friend, try to remove your battery and then installed it back then make it sure that the battery has the right amount of energy to supply the needs of your laptop. Also If the problems is still no display then kindly contact a technician in your place or find a service center near within your locality and let them fix and trobleshoot the problem. The usual cost of in fixing the problem is not much maybe a maximum of hundre dollars (if you are using US Dollar Currency). the worst problem if your unit has a defective parts then may be it defends the price of the defective parts will you spend.
SOURCE: HP Pavilion Dv6700 black screen after booting up
Go to the following HP website to view the problem and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=us&product=3636595&rule=21826
Hope you see what you are your looking for! Good Luck!
If you have any more problems let me know.
Thank you for using Fix Ya!
Don't forget to rate the overall satisfaction of this answer!
SOURCE: HP Pavilion dv6700 faulty video card.
Video cards are integrated onto laptop motherboards so you will have to replace the whole mobo and can cost between $150 - $400 depending on where you get one from.
Many people end up getting a new computer instead and sell their old ones for spares to make up the money.
Just out of interest can you tell me what is wrong with the laptop graphics as it may be as simple as the graphics drivers being bad.
Regards
SOURCE: Failed intrenal power supply on HP Pavilion dv6700
Before you go thru all that, HP has an extended warranty for 6 and 9K units with Video and Power startup problems.
They have added an extra year to the original warranty and it would be to your benefit to check first.
Email customer care and issue a repair request.
You can chat with a tech and find out in no time yes or no.
If you log a issued complaint, they may review it in your favor.
Testimonial: "Appreciate the comments."
I had tried that, the lever barely moves. I believe the lever should be on the right, pushing to the left to push the battery out. However, the lever accidently got pushed to the left while the battery was placed into the computer. The battery is a new lithium 12v battery.
the lever is on the left when my computer is facing me with the headphone jacks toward me with the cd/dvd drive on the left, instead of the right when in normal position.
