Question about Acer Computers & Internet
I have recentley wiped my harddrive and installed windows vista ultima my laptop is acer 5715z since i did this i cant find the options to turn the tapping off on my mouse pad it really gets on my nerves so can you please help?
    Scholar:
  • 60 Answers
Sounds like the touchpad driver you have is not the right one. Having a compatible one and the right one is the difference between XP and Vista. Also, sometimes on some laptops above, or below your touchpad, there should be a button. if you push the button, it should toggle between on or off..Or try to disable the "tap" feature in System Configuration, Peripherals, Touch Pad and be sure to click "Apply".
You can modify the xorg.conf file as follows,
As root edit:
/etc/X11/xorg.conf
In the touchpad stanza add the following lines...
Option "TapButton" "0"
Option "HorizScrollDelta" "0"
Then edit:
Option "VertScrollDelta" "0"
(if it wasn't already)
Save it, logout, reboot.
Last resort is to search microsoft knowledge base or your pc manufacturer. That seems to be a growing problem in vista but not seen in XP.
Posted on Nov 09, 2008
My Acer Aspire 5715Z has startup problems: This happend: Windows is loading files (not normal) then the normal starting comes up and then i come in but it says System recovery options so i put my...
Your hard disc has bad sectors.
That means your hardrive has a defect.
That why it is not starting up normaly.
You have to buy a new harddrive and a new windows 7.
to get the laptop running again.
Your pc can run windows 7 32 bit not the 64 bit.
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=547
Aug 22, 2011 | Computers & Internet
I have got a virus on laptop and don't have any protection and can't find the discs that laptop came with to wipe hard drive
As long as you have a Windows install disk you'll be fine. Just start the laptop with the disk in it, and you will somewhere have the option to format your harddrive. (you'll have to select advanced option in some menu) When setup asks for a license key, you should look for it on the laptop manual or the case itself. When Windows is then installed, the virus will be gone, and you will have a clean harddrive, but you'll also lose all your data!!!
If you have any questions, please ask them.
Dec 10, 2009 | Acer Computers & Internet
Blanking PC
1. Extract the HDD 2. Put it in any HDD USB case. Buy it in the nearest PC shop - 20 bucks worth 3. Connect the case with HDD to another PC and format it. 4. Put HDD back to laptop.
There are no another way to blank HDD. Cheers.
Sep 20, 2009 | Acer Aspire 4520-5582 Notebook
Where can i get software for acer aspire 5715z
uploading.com/.../Acer-Aspire-5715-5715z-Webcam_Bison_Driver_v7.96.701.07-Driver-For-XP_-_www.lapt...zip.html
or
rootvn.net/archive/index.php/t-14807.html
OR USE THE RECOVERY DISC. If you don't have one, you get get it here:
www.user-guides.co.uk/.../Acer/AcerAspire/Acer-Aspire-5715Z-Vista-Driver-Recovery-CD-Restore-Disk-155731.html
Jul 11, 2009 | Acer Aspire 5610-4648 Notebook
ACER CRYSTAL EYE WEBCAM
hi dear
please use driver from microsoft, installi it with manual way
oke
Apr 12, 2009 | Acer Aspire 5500 5570-2609 Laptop
I cant install autocad 2009 in windows vista 64 bit operating system.
I cant install Autocad 2009 on Acer Apire 5715z, when i try to install the operating system is not supporting
regards,
Johnson Idukkula johnsonkollam@gmail.com
Mar 05, 2009 | HP Pavilion dv4000 Notebook
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
Power was interrupted during initial start up and now cannot get to load
Insert the supplied Recovery CD's that came with your new laptop, and let it boot from the CD's. This will prompt you along the way to completely wipe your disk and pretty much start over... which is what you were doing anyway. =-]
Aug 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
