Question about Canon PowerShot A470 Digital Camera
Help! please i need help=)
Hi, my camera was exposed to the rain, but not too long, now when i try to turn it on there is a big dark circle on the screen, and the background is white with a mix of purple and green lines... can you help me?
i looked on the internet and the only solutions are if it's submerged in water, i'm pretty sure mine wasn't and no where else is wet, it looks like the inside of the LCD screen is wet.
Is it water? or something else? it doesn't look cracked..
Thank you please reply as soon as possible i need the camera!=(
  • 489 Answers
Honestly its hard to say without opening the camera and looking for corrosion.
To do this remove the screws in the outer body and pull the back off. You will either see corrosion on the PCB, maybe on the connector for the LCD cable or you won't.
Make sure the batteries are out when you do this!
If you don't see any then that's not the problem. =)
After reading what you posted again, it sounds like the LCD is cracked/broken and not corroded. Can you see old pictures or menus at all? Probably not, but you can still take pictures I am guessing.
If I saw the camera I could tell you right away if its a broken LCD or not. If it is we can replace it for about $65 including return shipping of the camera or you can buy the LCD and install it yourself for about $46.
Google: 'digital camera parts', we are the first listing, Darntoothysam com.
If we can help let us know!
Thomas D.
Owner, Darntoothysam com
Posted on Jun 17, 2009
I cant take pictures. its all white
Hi, try to recharge it.
Expose the camera to lightness and darkness.
See if that make any changes.
And I need to know, if you have drop the camera?
Jun 17, 2011 | Canon PowerShot A470 Digital Camera
The camera was exposed to rain and it won't even turn on.
Hello. Please follow these 5 easy steps:
1. The most important of all, DO NOT try to start your camera.
2. Loosen the battery cover, remove the battery and put it somewhere to dry.
3. Wipe the camera immediately with a paper towel or anything that absorbs water well.
4. Use a powerful vacuum to absorb the water droplets which you can't reach with a towel (such as those inside the case).
5. Put the battery and the camera in a bowl of uncooked rice by covering it completely. The rice absorbs the moisture from the air very well so that it will help drying your camera. Keep it there for 24 hours or so.
I hope it helps!
If you have any other questions, please leave a reply!
Thank you for using FixYa.
Tip by hiddenul.
May 30, 2011 | Nikon D50 Digital Camera
2004 malibu classic. When it rains, it will not start easily. Maybe after a dozen tries, it will start. When it starts, it runs fine but there are problems with some of the lights not turning on when they...
Hi
Check all your connections under the hood, and check to see where the water is penetrating, check especially the battery connects. Usually the cause of a no start in rain/high humidity conditions is that the spark voltage is arcing to the engine metal rather that to the spark plug because of worn out spark plug wire insulation. You may be able to observe this when the engine is running at night in a dark location when it is wet outside by opening the hood and observing for arcs jumping out from the spark plug wires. The distributor cap could also be cracked which can also short the voltage to ground. It is suggested to replace the spark plug wires and look carefully at the distributor cap for any signs of a crack.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 20, 2011 | 2004 Chevrolet Malibu
Hi i have dark circles under my eyes caused by pigmention circle delete 1 and 2 do not cover them makes under my eyes look ashy what do u recommended? many thanks suzanne
http://www.marykay.com.ph/mkpweb08/Products/product_cat.asp?id=skincare
check this site and you will find what you need.. Mary Kay have concealer that will hide your skin imperfections and eye cream that will help you to erase the dark circles under your eyes.. surely it will help you.. :-)
Apr 01, 2011 | Jane Iredale Circle/delete 3 Concealer...
I have a nikon coolpix l100 and I was wondering how to take pictures outside at night? what settings do I put the camera on? all my pictures outside at night turn out very very dark
There are nighttime settings for most cameras. This can be an auto setting where the camera will automatically detect the light level and set the exposure rate.
On a manual setting, you need to consult your manual as to the options of can be set such as:
aperture (how big the hole is to let light in)
f-stop (speed of the shutter)
exposure time (how long to expose the CCD)
Flash on or off.
all of these items should be explained in your manual.
If you did not get a manual, the please look up these items in a search engine to get an understanding of how to balance your exposures.
Flash photography is not the only nighttime way to take picture.
I hope this was of some help.
Sep 27, 2010 | Nikon Cameras
My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Jan 03, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Nikon d40x
It sounds like your flash capacitor isn't fully charged up and your taking a photo and there isn't enough power charged up, so your photos turn out too dark. Take a photo, wait for a minute or til you see the flash icon inside the viewfinder lit up and then try taking another photo.
Jan 01, 2009 | Nikon D40x Digital Camera
Cybershot DSC W7 screen only shows streaky lines
Hi
Sounds like your CCD or mainboard (PCB) is defective, possibly from the exposure to water. The CCD converts the light into a digital signal and the PCB is the 'motherboard' of the camera and does all the work, like a computer motherboard.
When you opened the camera did you see any corrosion? If so you can try and clean it off with rubbing alcohol, this may solve the problem. Check the cables and clean them if they are corroded.
If that doesn't work then you need to try replacing the CCD or the complete lens assembly if you can't get just a CCD... and if that doesn't work then you need to try replacing the main PCB.
We are a digital camera repair shop, (Google DARNTOOTHYSAM) if we can help please let us know!
Good luck from Darntoothysam com
Thomas
Oct 08, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
My Sony DSC-W50 just started taking dark blurry pics...
same here. had my camera about a year and a half when this started
Mar 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Optio s4 - help needed
You are probably in play mode and not in camera mode. Switch the camera back to camera mode (move the witch so its in the camera position- you will see a small camera icon) in order to take pictures.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
Canon PowerShot A470 Digital Camera Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
