Question about Sanyo DS27510 27" TV
Original problem the tv wont turn on and it doesnt seem to have any high voltage but i'm not really sure whats wrong.
    President:
  • 3,130 Answers
You could have a power supply problem or a sweep supply problem. If you have had any TV repair experience, you will need to get a schematic and go from there. if you have not and still want to learn, Please read the article im posting for you. A tv set is not a place to be poking around in if your not sure where to poke. Good Luck http://www.techlore.com/article/15116/ Please do not forget to rate this thread.
Posted on Oct 23, 2006
Hi i have a Vizio E470-A0 That wont turn on. I press the power button and it turns on for a second then fades or just cuts off.
Does your 12 volt remain at 12 after it shuts off or does it drop to 0?..This model was known for issues with the LED lamps themselves but Ive seen a number of sets where the LED's were fine and it was the power supply or main boards bad
Oct 16, 2017 | Vizio Televison & Video
What could be wrong with my Hi sense TV,it gives me a hissing sound,and does not light the standby light.
You listed this as a CRT model and a hissing noise from inside the unit means the high voltage transformer is leaking voltage. Turn it on in a dark room and look for sparks
Jul 23, 2016 | Televison & Video
I have plasma tv thats has been getting the pink bands across the screen when the image on screen is bright. It gets worse when cell light is turned up in addition to brightness.
You need to check all voltages there is a sticker on the back of the screen with various voltages these need checking with a digital meter.
Jan 06, 2016 | Samsung Series 5 51-inch PN51E530A3FXZA...
My car wont start! turn key - nothing.doesnt even
You certainly don't sound like a mechanic :>)
The fluid in the gearbox has no bearing on why your car doesn't start.
The most likely reason for this is that you have a flat battery. Put the headlights on, then turn the key to try and start. Do you have any lights or do they dim considerably. If so, you have a flat battery.
If not, it can be many things, but most likely the anti-theft system.
The high revving and lack of power is most likely caused by sensors in the engine, but could be caused by lots of reasons. You need a garage and diagnostic equipment, but first check the battery.
Mar 01, 2018 | 2000 Renault 181
The tv wont turn on
no high voltage take to tv shop
Apr 02, 2009 | Sony KV-36XBR400 36" TV
High pitch noise from the flyback
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Jan 23, 2009 | Samsung HL-P6163W 61" TV
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv wont turn on
it sounds like your flyback transformer or voltage trippler is bad
Sep 06, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
T.v. was hit by lightning and wont turn on
Check Q605 for short. Hope this helps
Nov 20, 2006 | Sanyo DS27510 27" TV
Sanyo DS27510 27" TV Logo
88 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
