Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Sound from streaming
When streaming a live radio show the sound slows down at times. I have also had problems copying a dvd (not copywrited and have used the dvd drive on another machine with no problems). The video will do fine almost half way through and then start getting choppy and a few have stopped.
My son put this machine together for me and I got the system info off the machine. It is and Intel processor, Pentium 4, 2.80 ghz with 1gb Ram
  • 1 more comment
  • lindajune Nov 09, 2008
    I ran the ccleaner...thank you for that info. But... I only listen to this program in the morning and it is the only thing I have opened along with email. Fire wall spybot and just a couple of icons that I'm not using are there. I'm not an expert by a long shot but could it be something with the buffering (hardware)?
    Dahaka
    I am running windows XP home edition version 2002 with Sp 3.
    I had been making copies of a cd to hand out on my old computer and there were no problems. Also listening to the radio stream was no problem. When I moved the DVD writer to the "new" machine I started having problems and that is when the radio stream started slowing down. Not all the time. Also not right away and not every day.
    I have moved the DVD writer back into the old machine and am able to make copies with no problems. The old machine/cpu couldn't handle the new 230 gig drive I put in. I learned that I needed to flash the BIOS with an update so that the addressing issue would be solved. I hope i said that right. I'm concerned about messing with the Bios but will probably go back to try that when no so pressed for time.
    Thanks for this help
    linda
    I first go tohttp://gcnlive.com/Listen_Live.html around 7 am central time. The program is called The Power Hour. It's a talk show. There is something streaming on this network all the time, I think. I click on the Network 3 Winapp (Windows Media Application) this automatically downloads and opens the application.
    My DVD copy program I use is 1click.
    linda
    Sergeant:
    Champion:
  • 347 Answers
Hello Lindajuane,
Are you running windows vista?
If so, 1Gb of memory ram is the minimum memory ram needed to run. I recomend you to upgrade to at least 2 Gb Memory Ram.
If you are not using windows vista, let me know.
Dahaka
Posted on Nov 09, 2008
  • Santiago Vallejo
    Santiago Vallejo Nov 09, 2008
    Hello Lina,
    You probably have many programs running at the same time on your computer, or maybe one or a couple are usign too much ram memory.
    When you start your computer, press: ctrl+alt+del
    The admin manager will appear. Go to the third tab (performance) and 2 graphs should appear.
    The 1st one tell you how much percentage of the procesor you are using (pentium 4, 2.8Ghz, isnt too powerfull).
    The 2nd graph is the amount of Ram memory you are using.
    While you are monitroting both graphs, do your normal work (this can be burning a DVD). Tell me what both graphics read.
    On the second tab of the administrator manager, You can see what programs are running, click on the CPU or Memory Usage tab (under the second main tab(proceces)) too see what programs are using most of the CPU and Ram memory of your computer.
    _______________________
    About the radio show that skips the sound. Do you have that problem while listening to any video or only the radio show?
    _________________________
    PS. Sorry for using terms as "the second tab" but my windows is in another language and i dont know exactly what the tab says in english.
  • Dell Master
  • 13,433 Answers
You may have too much running on the background, I would suggest to clean it up a little, http://www.ccleaner.com is a good useless file cleaner it wont solve all of the problem, I would suggest you remove programs that are not needed from runing on the background.. If you have a ton of icons next to your clock that may be the cause.
You can use add or remove programs to remove useless programs start -> control panel -> add or remove
If your intrested I can start a remote support session to see if your computer needs a clean up, its free of charge for you.
add a comment if intrested. Reposting will reject my support.
Thanks,
Ekse
  • Ekse Nov 09, 2008
    What program are you using to listen to the radio? My vlc media player starts skiping on online play sometimes and I just press stop and then play again to fix the problem.
    It sounds odd that the show would slow down... but let me know what program your using to listen and if you could also tell me what radio it is?
    Thanks
I have unlimited talk text and data, I use internet sharing to my DVD player for Netflix it keeps stopping and loading how can I fix this, it will play for maybe ten seconds and stops to load
Netflix needs a fast download speed I tried netflix but my ADSL2 landline but it was too slow and I experienced this annoying behaviour . Unfortunately Netflix and other movie providers do not let us download ahead of the movie to allow for delays or errors in transmission slowing down the live streaming. Fibre optic data stream land service would fix this I am not sure on g4 mobile data as it is faster than g3 mobile data but is not always available when radio channel slots for g4 as used in an area . G3 is a revert to service when g4 is not available. Phone has to have g4 capability also.
Aug 10, 2015 | Televison & Video
I have a Roku 3 which uses the Internet to access Netflix. My ISP gives me unlimited access during 23.00 and 07.00. Is it possible to down load a film during these hours and view it a few hours later
Netflix will only load the stream for a short time before it stops, streaming must be done live but you could pause it but doing so all night would not be of much help. Just start and hit pause 10 to 20 minutes before you really want to watch a film or show. If this is really a problem you may need to improve your internet capability either through increasing speeds, getting a plan with less throttling, or moving the router closer to or connecting directly to your devices. Other than that you could download movies and avoid the problems of streaming altogether.
Nov 21, 2013 | Roku 3 Streaming Media Player - 4200R
Pc suddenly slowed down severely and any sound (you tube video, radio streaming, any other video already on my pc, even the initial start up sound) stutters with deep and prolonged metallic sound
I advice you to thorough scanning of your machine. If it still behaves the same, You may consider backing up your files and re-formatting the machine.
Apr 26, 2011 | Acer Aspire 5672WLMi Notebook
My DVD recorder is telling me "Input Source Protected" when I try to record. What does this mean?
This means the material you are trying to record is copywrite protected and can't be recorded. This can come from other DVD's or even certain brodcast programs are copywrited and therfore can't be recorded. I Have heard there ia abox you can hook to the DVD so it will remove thes copywrites but I don't know if they are still for sale. I hear someone tell me that he got his at Best Buy but that has been a few years back. If you have a computer and can go online, there is a program called DVD Fab decrypter that can remove the copywrites to most DVD's and you can make a copy on your computer to watch in your DVD. Just look up the DVD Fab Decrypter and check out their site. There is a cost for this program but I thought it was well worth it, I have made personal copies of many movies using this prgram.
Nov 14, 2010 | TruTech TT1620 DVD Recorder
I have a lg rh339h and I want to dub a copywrite dvd.
No, you must download a software inorder to do that. a movie maker or a software that will be able to dub after you have copied it in the hard drive.
Mar 29, 2009 | EliteGroup ECS P4M800-M7(3.1) LGA775 ALL...
Copying my vhs movies to vhs
I find that after 2 years of using my Sima CT-200 GoDVD that I can no longer recored movies from my DVR player. I get an error saying copywrite and shuts off my DVD about 30 seconds later
Sep 24, 2008 | Sima GoDVD CT2 Copy Master Digital Video...
Manual
Go to this link to get your manual :
http://www.microboards.net/filemgmt_data/files/CWLivemanualver22.pdf
Apr 26, 2008 | MicroBoards CopyWriter Live (CWL-212)...
Recording to dvd from sky + box
It sounds like you are catching the Macrovisiin copy protection on certain shows. I've personally never experienced this with my Panasonic unit while trying to record from television.
It is a bit weird. Have you checked their website to see if you can upgrade the firmware (internal programming) of the player?
Feb 17, 2008 | Televison & Video
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
18 people viewed this question
Alun Cox
