I have a Samsung HLS5086wx/xaa Tv 2 years old, and it keeps shutting off by itself, I reboot and it lasts for awhile, and starts up again, the warranty repair tech does not know whats wrong
5 Suggested Answers
SOURCE: television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Posted on Jul 17, 2009
ladywinn
  • 5138 Answers
SOURCE: Samsung HLS5086WX-XAA after 1 years it's showing dark
Light Engine or the DMD board 1-800-638-3328
Posted on Jan 14, 2010
  • 69 Answers
SOURCE: white dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Posted on Feb 07, 2010
techman007
  • 1112 Answers
SOURCE: samsung dlp 50" hls5086wx/xaa when u watch tv for
Hi:
Replace the lamp, if its not been replaced since you brought the set then its time for a new one..
Posted on Jun 14, 2010
Is there any way to buy a CPU for HLR5667WAX/XAA? How to replace it?
If you TV is 9 years old it is questionable whether further repairs are economically worthwhile.
Jun 05, 2014 | Samsung Cooling Fan Set for HLR5667WAX/XAA
Hls5086wx xaa
It could be a defective color wheel or stuck light engine cooling fan.
Oct 17, 2017 | Televison & Video
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Samsung TV Model HLS5086WX/XAA turns off by itself
Not clear if set makes it on or not---its a DLP which uses a lamp for brightness so start there and next would be to inspect the color wheel that faces it directly--no broken or missing pieces there?
Nov 01, 2012 | Samsung Televison & Video
How do I replace a lamp ballast in my Samsung model # HLS5086WX/XAA?
The ballast should come out fairly easy---at the end of the 2 red wires where it connects to the lamp should be a single screw and the lamp has to be already removed---with the screw at the wire end removed the socket lifts up and to one side and the actual ballast is secured with no more than 4 screws and has only one or two small plugs to remove
You might also check You Tube to see if they have video instructions there for your model.
Mar 20, 2012 | Samsung Televison & Video
I replaced the lamp on my Samsung HLS5086WX/XAA DLP set. How do I reset the timer on the lamp?
I have a Samsung DLP HLN617WX/XAA. After turning off by itself, the three indicator lights were blinking... signifying a defective lamp. I've re-seated the old lamp several times with no change. I bought a new lamp and reset the lamp hours through the "service menu" with no change. My television is still turning itself off and still blinking the same indicator lights. What should I look at, next?
Oct 26, 2010 | Samsung Televison & Video
Jan 14, 2010 | Televison & Video
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
Samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Jul 05, 2009 | Samsung LN32A550 32 in. LCD TV
Televison & Video Logo
717 people viewed this question
Top Televison & Video Experts
