Question about Sony PFM-42V1A/S High Altitude 42 in. HDTV-Ready Plasma Television
My Sony Plasma Display
I have one black horizontal line when I turn on my plasma tv, how do i make it go away although it will go away after awhile
GT
  • rayk591 Mar 09, 2009
    i have sony plasma pfm-42v1a.when i have the full screen on i still see the smaller screen lines on the side.
    could anyone tell me what to do to remove lines
    thanks
  • 320 Answers
It sounds like you have a bad connection from either the X sustain or Y sustain boards to the panel itself. After the set warms up, the connection completes and the line goes away. First remember there are DANGEROUS HIGH VOLTAGES IN THE SET AND YOU CAN BE SERIOUSLY HARMED OR KILLED IF YOU TOUCH THE WRONG THING SO BE CAREFUL!. I would get a non conductive probe of plastic or wood and, with the set on and the back off, push on the ribbon cables which connect from the sustain boards to the panel. Once you determine which ribbon cable is the problem, disconnect the power, wait AT LEAST 30 MINUTES FOR THE VOLTAGES TO DRAIN OFF and then carefully resolder the ribbon cable connections at the sustain board in question. If the problem is at the panel end of the cable, I wouldn't recommend you try soldering there as it is very easy to damage the panel connections. You may try simply repositioning the ribbon cable to see if you can find a spot with a better connection. Please be sure to rate this solution. Thanks!
Posted on Nov 09, 2008
Sony tv when i turn tv on only shows vertical lines then they slowly fade away and goes black
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 14, 2017 | Sony Televison & Video
Horizontal lines and black spot in corner of led tv
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 09, 2016 | Samsung Televison & Video
How to fix black horizontal lines on samsung plasma tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 10, 2016 | Samsung PN50C450B1DXZA - PN50C450 50 720p...
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Have a Samsung 50" plasma tv with horizontal black
There are two possibilities for this fault. If COF module has any loose contact, or, display itself. If you wish to get more details about these type of fault to Plasma display, check the link given here. It has screen-shots of defective plasma dislay. Compare them to that of your TVs' and make sure. http://electronicshelponline.blogspot.com/ View it in Timslide option.
Jun 30, 2013 | Televison & Video
Thick lines descending plasma screen
maybe you have interference with other electrical component near your tv. move the component, example cable box, dvd, sat box.
Apr 14, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Samsung LCD Flatscreen only shows lines of color or purple dots
Jun 18, 2017 | Philips 42HF7444T 42 in. Plasma TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Sony PFM-42V1A/S High Altitude 42 in. HDTV-Ready Plasma Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
