Question about Toshiba MW24F52 24 Inch TV with DVD / VCR Combo
Sound the sound has a loud noise connected to it.
0 characters
1 Points
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help ยท Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
? 9:23
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help -
Dec 30, 2015 | Magnavox DVD & Blu-Ray Players
My Panasonic dmr-es35v has decided to cease recording, and makes loud grinding noises, any ideas, reset?
You can try a reset, but I doubt it would do much good. The loud grinding noises and failure to record sound to me like the DVD-RAM drive has had it. This sadly is not a cheap part to replace, and there's the issue of fitting/alignment/firmware upgrade etc.
Uneconomical for a model that is over 4 years old (since it has no digital tuner).
However, if you are prepared to spend a small fortune on a workshop repair/replacement DVD drive, go ahead, but I warn you it could cost as much as, if not more than the price of a new VHS/DVD recorder combo unit.
Feb 10, 2011 | Panasonic DMR-ES35VS
The left speaker of my denon s-301 makes short loud distortion noises.
Try unplugging the right speaker and plugging the left speaker in the right port. If the speaker still sounds distorted then you know you have a brocken speaker. If it sounds normal then we know its not the speaker.
Sep 25, 2010 | Denon S-301
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Loud mechanical noises from my dvd player during loading,advcing,
hi..the reason for the problem is u have
to clean ur dvd lense.u can clean the lense
using the lense cleaner cd.This will be available
outside.once u clean it will work properly without
any noises.
check it out.
thank u..
Feb 07, 2009 | Philips DVP5140 DVD Player
My dvd player is making a loud humming sound when i load up a dvd. it is the phillips dvp5960
Does the DVD player still work, even though it's making the humming noise?
The humming noise may just be normal for that machine. Turn your TV up louder .
If the player doesn't work, the drive is broken, and you would have to send it to Phillips if your warranty is still working. If the Player still works, check to see if the disc is warped or cracked, this'll make the drive unstable, and make the noise.
Hope my answer helped :)
Nov 16, 2008 | Philips DVD & Blu-Ray Players
I had a similar problem, particularly when trying to use the DVD recorder, and when I turned on the unit it made a loud rapid clicking sound, and then immediately shut off. It appears to have been the VCR section of the unit (which I rarely use) that was causing the glitch, and the pragmatic solution was to simply leave a blank VCR cassette in the machine all the time. Then I was able to use the DVD recorder without the noise and shut-off problem. (posted 2009-07-22)
Jun 23, 2008 | GoVideo DV1030 DVD Player/VCR
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
Loud buzzing noise
Out put Capacitor breaking down - needs a serive replacement if available.
Nov 13, 2006 | Sony DVP-NS55P DVD Player
Toshiba MW24F52 24 Inch TV with DVD / VCR Combo Logo
13 people viewed this question
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
