Question about Motorola DCP-501 Receiver
Box my box only reads 99 chanels where are the other 900
  • Anonymous Nov 12, 2008
  • ravila Nov 12, 2008
My box only reads 99 chanels where are the other 900
Posted on Nov 28, 2008
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
I'm having problems with a Behringer PMP5000 board. the dual effect chanel instead of number 0-99, it come up as letter and number i.e e1-5
In spite of the display, does the effects work and do they change when you dial up and press the knob down? If they do, then likely the display is at fault. If the effects are NOT working sound wise, check the +5 volts as the whole effects runs from that, It should be within 10% of the 5 volts.
Sep 30, 2012 | Behringer Europower Pmp5000 Powered Mixer...
My Starview Box super Usb 2 has lost all the movie, music and international channels etc. Is there a way to get them back?
I had the same problme on my Starview 1 lost all sprts chanels and movie chanels. To day it wont let me watch Movie chanels and Overs on my Chipped V+box but it still lets me watch Sky sports and Espn. Have you tyred to do factry defaults settings on the starview box that can sometimes help. And make sure you turn EMU on.
Aug 03, 2010 | Televison & Video
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Aug 16, 2009 | Televison & Video
My savvy has lost suction. I checked for blockage in hose and is ok. The filter basket is clean. the motor runs strong. What else could it be?
facing the back you will see 2 chanels one on the left where the hose comes out and one on the right that entends down into the base.start with the one on the left,its shaped like a j..there are 10 screws take those out and clean the chanel.be careful of the thin rubber seals around the outewr edge of the chanel that you take off.next is the chanel on the right,it starts where the hose sets in when not using it.there are seven screws.be sure to fold the vacuum open and lay flat on the floor.those seven screws will seperate the upright from the base.clean that out.when you take that off you will see a long slot going across ,that is your main suction intake.also be careful of the thin rubber seal around the outer edge.if there is a blockage it will be in one of those two places.please leave feedback
Aug 12, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
There is no suction
check for blockages and clean your filters
Jun 24, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
My 99 cbr 900 has no spark from plugs. Replaced the plugs and coil pack and still nothing. Wondering what coils ran what plugs to be sure connected properly. Battery seems fine. Have a cdi box on the way...
i had the same problem on my 97 fireblade it was the rectifier (voltage regulater), try unpluging it and see what happens it is located under the rear plastics it has fins on it too help keep it cool and should have 3 yellow wires, 1 green and 1 red on the plug
May 16, 2009 | 1999 Honda CBR 900 RR Fireblade
Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
Oct 18, 2008 | Boss Micro BR Digital Recorder
Motorola DCP-501 Receiver Logo
60 people viewed this question
Top Motorola Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
richie46
Are you a Motorola Audio Player and Recorder Expert? Answer questions, earn points and help others
