Question about Clarion DRX-9675Z CD Player
Unit scrolls "Goodbye!" and shuts off and on spontaneously
This unit was working fine, then one day it scrolled across "Goodbye" and shut off for a while, blank display. It appeared not to be getting any power, then it turned back on again. Now when it happens it says "goodbye" and then turns right back on again. I thought maybe it was a loose connection, but why would the unit be scrolling "Goodbye" if it was a loose wire? I have cleaned the contacts and taken some canned air to the front of the unit. Any help would be appreciated. Thanks.
    New Friend:
    Problem Solver:
  • 8 Answers
Sounds like a bad ground or something else shorting out make sure that you have a good ground and hot wire to the unit because it sounds like that's what it is floating ground or a loose ground
Posted on Feb 13, 2018
    Top Expert:
  • Clarion Master
  • 2,931 Answers
It is receiving a signal to shutdown and restart. This sounds like the power on selector may be dirty or damaged. It may require disassembly to get to the switch or contact pad.
If all else fails, I recommend contacting a local car audio professional, or you may contact Clarion customer support directly by clicking here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information has proven beneficial.
Unit scrolls
5 Suggested Answers
SOURCE: NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Posted on Jul 08, 2008
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
mrrosco08
  • 14 Answers
SOURCE: Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Posted on Jun 10, 2010
SOURCE: clarion vrx745vd shuts down before completing the power on seq.
you probably have a loss wire I just want though that
Posted on Sep 15, 2011
I have ge he sensor model gtdn550ed0ww it keeps showing se pa au u5 I can't find out what that means and it keeps shutting off after a few minutes and then it turns itself back on but it won't dry and only...
Your machine is scrolling the word "PAUSE" across the display. Simply press the START button and it should resume operation. The display will look like this:
pa
au
us
se
Repeat
If pushing the start button doesn't work, check to make sure the door lock is working. This video shows a similar model:
If the door lock isn't bad or doesn't repair the unit, you may have a wiring or control board issue. All these units have a tech sheet included somewhere in the cabinet, with a list of field-replacement parts and a wiring diagram. My guess is that a control board for this unit, or a switch panel, will be hundreds of dollars. Pray for a cheap repair.
Jan 07, 2015 | GE Dryers
The scroll number lock goes on by itself
you can just press function+num lock and then it'll turn off and on when you want it to
Mar 30, 2009 | HP Pavilion ze2000 Notebook
I have a samsung home theater system HT-X70. After 10 to 15 minutes the word protection scrolls across the screen then goodbye and finally the unit shuts itself off.
ther is dc voltage applying your speakers by amplifire itself and turn on speaker protection circuit itself.
it can be happens because
1.loose connection in amplifire board
2.faulty output section of amplifire
3.short circuit of speakers
4.error detecting circuit faulty.
if youcan open the cover and clean the circuit for dust and resolder the circuit with 30 W soldering iron cairfully.if you want the more asistence please come again
ican hlp you more.
Jan 08, 2009 | Samsung HT-WX70 Theater System
Unit shuts itself off after 10 -15 minutes
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Microsoft notebook mouse 5000 Wheel scroll stopped
Fixing the wheel/scroll malfunction was as simple as a reboot. I usually shut down in hibernate. Apparently the system needed a complete reboot to reset.
Thank you for following up.
Nov 22, 2008 | Microsoft Wireless Laser Mouse 5000
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Protection
Protection means the unit is detecting a short somewhere. Disconnect speakers and components and attempt to power on the unit again. If it will power on with nothing connected, repeat the process (turn off, connect something, then power on) until you find the bad component or speaker.
Jan 24, 2008 | Samsung HT-DB120 System
Tuner error
Use a multimeter to check for connectivity to the sirius. Where did you mount the antenna? Maybe its a reception problem? Sounds like the head unit is going bad. Try shutting it down, and take the pace plate off, let it reboot and see if it works. Check to see if the Tuner is unplugged.
Nov 16, 2007 | Kenwood Sirius KDC-MP225 CD Player
Clarion DRX-9675Z CD Player Logo
41 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
