Question about Electric Jazzy 1115 Power Wheelchair
Charging a MPV4 hoveround chair
My neighbor just bought a "used" MPV4 hoveround chair.. The problem is he didn't get any instructions and doesn't know how to charge it.. Can you tell me if it has a built in charger ? and if so where it's located? or do you have to have an external charger, but if so where does it plug in??
Thank you.
The battery charging connector, which may appear as the female connector of a stage-quality microphone, is underneith the Joystick control arm. An external charger should have been provided by the seller, so if you don;t have one, you'llhave to contact the chir manufacturer.
Posted on Dec 24, 2008
How do you get the seat too swival on my mvp-4 hoveround power chair
Hoveround manual:
Took the answer right from the manual. If you would like a digital copy of the manual, the link is posted below.
[The swivel seat permits the seat to pivot from the forward facing position through 90 degrees in either the left or right directions. The seat will lock in each of the forward, left and right facing positions. This feature is provided to make side transferring easier. The swivel release lever is mounted on the left side in the standard
position]
http://www.hoveround.com/.../MPV4-Power-Chair-Manual.pdf
May 21, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Schematic information on Pilot Penny-Giles controller for Pride jazzy or Hoveround MPV-4 etc.
I've never had much luck getting information like this for most joysticks, and have never gotten it for Penny+Giles stuff. You may have the best luck looking for a used replacement joystick on eBay or Craig's List.
May 17, 2014 | NRS Hoveround MPV 5 - Used Power...
Hoveround MPV4
Check your battery connections, make absolutely sure it is connected correctly.
Place a multimeter in the XLR plug (joystick). You should have around 26V reading if batteries are connected correctly.
Check the free wheel levers. place the chair in free wheel and move back and forth a couple of times. Place the chair back into drive, turn on controller and try to drive. ( This is not typically associated with a clicking sound but will ensure your brakes are not on)
If you are still hearing a clicking sound, it could be a problem with the brake or a motor. A qualified technician should really look at it for you.
Apr 19, 2014 | NRS Hoveround MPV 4 - Hovaround Used...
Hoveround mpv4 won't charge Why?
If you obtained the Hoveround directly through Hoveround, please contact them for expert solutions. http://www.hoveround.com or 1-800-96-HOVER. They made the chair, they KNOW the chair best, and can provide the right answers!
Oct 28, 2011 | NRS Hoveround MPV 5 - Used Power...
Need manual for hoveround mpv4
Hoveround doesn't publish the manual online. Go to their website and get the contact number to call and request a manual...usually at a fee...they ****. Next time, buy a Pride, Invacare, or whomever has the owners manuals online.
Jan 27, 2010 | NRS Hoveround MPV 5 - Used Power...
I have plugged the Soneil battery charger into the MPV4 Hoveround for over 24 hours. Although the indicator shows charging in process, the "battery charge indicator" shows it still requires a substantial...
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
Nov 01, 2009 | NRS Hoveround MPV 5 - Used Power...
Hoveround rear tire needs inflating
I don't think you have an MPV4. That model has 2 rear caster tires that are solid and require no inflation. The front drive tires have a valve stem sticking out of the center rim that is easily accessible. Make sure your power chair is gray and says Hoveround on it.
Apr 24, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
I need an instruction manual for a Hoveround MPV 4 Power Wheelcha
Call 1-800-771-6565 extention 5000. You will need the serial number of the chair and then they will get you a manual.
Mar 30, 2009 | NRS Hoveround MPV 5 - Used Power...
Need to test Hoveround mpv4, batteries are dead
No you will have to have proper working batteries.
Mar 19, 2009 | Electric Mobility Power Electric Scooter...
Electric Jazzy 1115 Power Wheelchair Logo
859 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
