FixYa.com
Tags:
Toshiba SD-KT50 System
Protection
posted by jammr on Oct 23, 2006
My unit will play a little bit then stops and says protection and then good-bye.
Please help!!
Thanks
Comment by jammr, posted on Oct 23, 2006
I unpluged all speaker wires but I get the same (protected) but it will play a CD. Now it will not stay on long enough for me to get the DVD out. Hello and then Protection and then good-bye.
Help,
Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
techman
Rank:Guru Guru
Rating: 87%, 6564 votes
It seems the unit has a thermal overload issue. It could just be an adjustment, or a defective part is going bad. Also try and check all the speaker wireing for pinches or shorts. Also have the speakers checked as maybe one is going bad and overloading the output stage. If you do all these things and it is still shutting down then you have no choice then to have it tested on a bench at a repair shop or replacing it. Good Luck
PS Please dont forget to rate this thread.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Home Theater Systems problems?
Speaker Wires
I need the wires for three of... Answer This...
my system stopped wroking with...
Toshiba SD-KT50 System my dvd... Answer This...
Unable to set FM radio in INDIA
I purchased Toshiba SD-KT50 in... Answer This...
TOSHIBA SD-KT50
My Toshiba Home Theater System... Answer This...
how i can fix my mpeg on my...
i can see the picture of the... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
