Question about Music
Repair Roland HP2700?
One key on my HP 2700 will not sound.
Nothing has been spilled on it. It was transported from one city to another.
2 Suggested Answers
  • 5603 Answers
SOURCE: I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Posted on Nov 01, 2009
Testimonial: "bur isnt it strange that certain keys have stopped working? ie most the A keys"
I'm having trouble being able to select any of my sounds or switch octaves or keys on my Roland RS-50 it seems as if it's stuck.... What do you think I should do
Will probably need to be diassembled and cleaned. Either a sticking key or a compromised contact on the circuit board. Any electronics repair shop should be able to fix this.
Jul 03, 2016 | Roland Music
Roland EP50 F sharp does'nt work.All other keys are fine
EP-50's are notorious for problems with either the 4.65 voltage feed to the velocity sensitive keys or failure of the small zenner diaodes. Each key has a pair fo split circles on the circuit board under it. When you hit the key you connect each side of the circles and the harder you hit the keys the quicker the circuits close the louder the sound. Problem is if the voltage to either circle fails, due to bad solder, scratch on circuit board, failed diaode then the sound disappears. The fix is simple if you are knowledgeable on solder on circuit boards, can use a multimeter and can dissassemble and reassemble the keyboard. If you have to take it to a repair shop it is probably not worth fixing as this is not one of the better Roland products
Dec 03, 2012 | Roland Music
Replace broken hammer key on roland kr 575
I've actually repaired two broken hammer keys on my Roland KR-575, after paying $250 (TWICE) for a repairman to come to my house and fix two other keys.
The repair I completed was about four of five years ago. I searched the internet and found great instructions to print out. Unfortunately, I can't find them again. HOWEVER, I did find this video: Roland Keyboard Repair. It shows you the hardest thing about the repair - how to take the cover(s) off to get to the keys! The video is not as detailed as the instructions I used before - but pretty good. The parts cost me about $25.
Unfortunately (for me) I have yet another key to fix now. This time I will take pictures and notes and update here with my results. It might take several weeks though (I'm trying to finish a big school project). In the mean time, try the video. I don't recommend trying super-glue like the video says, but sometimes finding parts is difficult, so I guess that might be an option if you couldn't get the parts easily. I just don't think a weight repaired with super glue will last very long.
Here are a few suggestions to find the parts you will need:
My other advice is to keep careful track of all the different screws you take out - and away from kids, grandkids, and pets - so you can put them back in the right place after your key repair is finished. (The screws that is ;)
Apr 22, 2012 | Roland Music
Hi, I am undecided about which digital piano to buy: Yamaha Arius 141 or Roland F110? help appreciated, thanks, karol.
I have two Yamaha's and I will say they are maintainable. Almost ALL the weighted piano key models use a keyboard made by one company as I understand it. I can easily get service manuals for the Yamaha, not quite as easy for the Roland... same goes for repair parts. Your decision... listen to each and decide. Hint: Use a set of headphones to do the compparision rather than internal speakers as the orientation in a music store can drastically change the sound.
May 01, 2011 | Roland F110 Compact Digital Piano 4867
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Transported Roland KR-177, toppled - pedal assy needs replacing
Good grief! FInd a tech that knows what he is doing. You can replace the plug and/or the jack. Each is a few dollars at most. You can even do it yourself. If you can see where wires went just buy new parts. They are probably available even at Radio Shack.
Oct 03, 2009 | Roland Music
Have a HP 1700 Roland Digital Piano that has one key (first G to the right of middle C key) that is off.
It sounds as if the membrane under the key needs to be replaced. It can be done with some careful work yourself but you might want to consider having it serviced by a Roland dealer as apparently the parts are becoming scarce. Hope this helps.
Aug 18, 2009 | Music
Roland Dp 2 Damper Pedal dont work
I'm 90% sure the pedal is shot ... It could be the switch ... Open the thing up (If your confident) and look to see if a wire has come loose ... If no wires are loose then try another working pedal with the keyboard.
If it still won't damp then there is a problem with your keyboard and I do not suggest opening up one of those ... I used to repair sockets and keys on those for a local boys school and there are full of things that can break if not opened properly,
My suggestion is getting someone in to repair the keyboard if its that ... If its the pedal then either get a new one if you don't want the old one repaired ... Or repair it yourself (pretty easy if its the wiring ... fiddly if its the switch but only attempt if your confident and have the proper tools).
Apr 23, 2009 | Roland Dp 2 Damper Pedal
Roland keyboard
You need to clean the pcb and remove dried spillage residue
you could try wasking the rubber contacts but these may need to b ereaplaced.
Jun 28, 2017 | Music
Music Logo
164 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
