When we try to do a channel scan, the screen says no channels picked up as it goes from 0-100% scan...this happens on manual and automatic scan
  • 3 Answers
On antenna mode change to cable w/ cable direct to t.v.If aconverter box is hooked up to t.v it wont read channels.
Posted on Nov 09, 2008
How to tune in Channel 60 in a Sony Triniton CRT?
assuming that you can "pick up" channel 60..and that the signal is strong enuff...that is part one..make sure you have a good antenna connection and that the antenna is positioned for maximum pick up, then do the scan mode on the tv via the remote control. it will re scan the channels and if the signal from channel 60 is being picked up strong enough, it will program the channel into your set automatically.
Sep 03, 2014 | Televison & Video
Sony bravia no digital channels
If you've tried different antennas did you attempt to re-tune/re-scan for additional channels after switching? For digital channels to be detected they must be scanned for, so consult your manual on how to perform an automatic scan of the digital channels available in your area.
Mar 27, 2014 | Televison & Video
All the channels have been lost and when i re-scan it goes to 50% then stops
Check and replace the main system control memory IC. It is faulty.
Apr 14, 2013 | LG 42PC1D 42 in. Plasma Television
TV displays "no signal" with every input type we try. The only thing that works is the DVD. I even tryed it on a cable cord that was working from another TV
hello are you using a digital antenna, cable or satelite reception? you need to run your "set up" and scan for channels either automatically scan or manual scan, recomend a auto scan for all channels both digital and anolog, these tv will scan and save or store the channels but you need to run a channel scan first,
(even if your using a cable box or sat box)
back when we had the older anolog sets you could just plug it in and watch but with these new digital circuts need to scan and store the channels in before you can watch the broadcasts,, try that let me know what happens. hope this helps
Jun 05, 2010 | Olevia 227-S11 27 in. LCD TV
L/o on the screen only picking up 1 chanel
Do you have frequencies programmed into the other channels? Use the MANUAL key to advance through the channels. If each shows a frequency of 000.0000, you need to program the scanner. It will automatically show LOCKOUT for each unprogrammed (000.0000) channel.
Bill B
May 10, 2010 | Uniden BC60XLT Handheld Scanner
Sanyo Plasma DTV turns it self on
No solution sorry but i have a problem too... I usually watch my tv on "dtv" now it just went black no channel is working it automatically went to "ATV" where the channels are fuzzy and my extra channels aren't working. I tried scanning on "DTV" for all the channels but automatically scanned and defaulted back to "ATV". Does anyone know how to fix this?
Mar 26, 2010 | Sanyo Televison & Video
Olivia 42'' flat screen and cant get any cabel channels
make sure that you're not using a cable box. then when you do the channel scan, make sure that you pick cable instead of antena.
Jun 18, 2009 | Olevia LT37HVS 37 in. LCD HDTV
V-scan channels missing
Sounds like all that is happening is that the channels are locked out, you need to go through manually and unlock them. I have the same scanner and that is what I needed to do.
Feb 12, 2009 | Radio Shack Pro-96 Scanner
Blocked Channels
Look for a reset to default feature in the settings of the TV. That should release the unblock feature and should pick up all channels during the scan.
Nov 30, 2008 | Disney 13" TV
Only receive 2 channels.
Can you punch in the channel numbers directly to go to the channels, but just not tune to them with the Channel Up/Down buttons?
If so then try tapping the favorite button on the remote until the screen shows "favorite mode off". This mode likes to stay [or perhaps turn] on when you scan for channels, but scanning clears everything in the favorite list except for the channel you are on when you start the scan (so it seems), thus leaving only one or two channels showing up. (This happens whenever I re-scan for digitals.)
To pick out favorite channels, go into the channel menu in the tv menu and with "Favorite: Analog" or "Digital" highlighted near the top, hit OK on the remote to toggle favorite status.
Nov 28, 2007 | Mintek DTV-263 26 in. TV/DVD Combo
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
