Question about ASUS Computers & Internet
Power fluctuations Hi My monitor is constantly flickering. I have a belkin surge protector plugged in as well. Can you help?
  • 3 Answers
If your only problem is the monitor i.e. no system lockups or unexpected re-boots that could be associated with an interrupted power supply, I would suggest the problem lies with the monitor itself, could be something a simple as a loose connector, have it looked at by a pro.
Posted on Nov 09, 2008
How do i Fix New Nonworking Belkin 8 outlet surge protector? Plugged in once, tripped the circuit breaker, now doesn;t work at all.
Hi
The link you mention relates to Belkin's range of computer cards and network equipment. The drivers on this site will not help you at all since the Surge Protector is related only to the power supply to your machine. Its purpose is to prevent surges and dips in the electrical supply that might be harmful getting to your electronic equipment and damaging it. They require no drivers and have no means of applying them either.
If it blew the circuit breaker the first time you used it, and it doesn't work - anywhere - then its faulty. You mention that it is new, therefore don't make any attempt to repair it, open it or anything, just take it back to where you bought for replacement, since it was clearly not of "merchantable quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Computers & Internet
I have a Princeton VL193 monitor and recently in will just power down. It just shuts off. If I unplug it from the surge protector and plug it into the wall outlet it comes right back up. When I plug it...
Monitor is erratic in operation - Power supply issue. Sooner or later the anomaly will become permanent and it will not power on. Just be ready for the eventuality.
Sep 14, 2017 | Princeton Digital VL193 19 in. Flat Panel...
I have a Dell LCD monitor (model number: E198FPf) that will not turn on. The power button is flashing and the monitor has a faint flicker with no discernable image. I removed it from the computer that it...
i believe you may have answered your own question here because what you are stating is a malfunctioned monitor if you plugged other monitors to the cpu and they worked and the monitor in question is not working maybe it was a storm surge and since it did not have a surge protector then maybe the monitor is shot and you may need to replace the monitor...
hope this helps
Feb 21, 2011 | Computers & Internet
Got a new surge protector/power strip. I
Hi
Please try the monitor without the surge protector to ensure there are no isues with the protector
If the monitor comes on you know its the protector, if it still fails then i recommned the following
1) ensure the fuse in the plug is ok and not blown
2) Change the 3 pin power socket for another one
If after this all fails then for some reason something has blown in your monitor and you will need to book it in for further inspection
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
Feb 12, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Screen is blank
Hello
The issue might be that your monitor is not getting enough voltage to turn on properly.
If the monitor is plugged into a surge protector, remove it and plug it directly into the wall outlet. If the monitor works fine, the surge protector is not allowing enough power thru it for the monitor to work correctly - replace the power strip.
If there is no change, then your monitor is going out.
Dec 03, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Donno how to use
Surge protector, minimizes voltage spikes or burst that could damage your electronics. You may not see it doing anything but it does. It clips those voltages to the right rating befrore letting them in to your system.
I hope this helps.
Jun 14, 2009 | APC BE325 SURGE PROTECTOR + BATTERY...
Just bought Belkin surge protector 8-way with telecoms.The 3 ports are lablled "output" (2) and input (1)>I have broadband external modem (ADSL) and internal modem for use with fax.The...
Does the surge protector have a "in and out" phone socket? Plug everything into the "out" side and then run a "phone wire" from the "in" side into the wall socket,.. you should be protected.. You are putting "all your stuff" after the surge protector.. so the surge protector can do its job..
Jul 18, 2017 | Belkin Computers & Internet
Computers & Internet Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
