Question about Creda IWD12 Front Load Washer / Dryer
Creda Easy Load Dryer
Drum is only rotating in one direction, after belt replacement. Any suggestions???
  • Creda Master
  • 3,463 Answers
Sounds like the timer is the problem, the reversing contacts have probably failed
Posted on Dec 01, 2008
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Creda tumble dryer not heating up, drum is rotating with no probs, filter is clear, any ideas please?
either heating element is faulty or the stats are faulty...............
easy fix.........
Jan 16, 2011 | Creda W120VW Front Load Washer
Which direction should the drum rotate on a gas dryer? the drum barely moves under load. I had the belt loose while cleaning the dust & lint from inside the motor, now that everything is re-connected ,...
The belt routing can be kind of complicated on some dryers.
Post your dryer brand and model and we can help you with a picture or diagram.
You can search the web for your dryer model, with "belt routing" or "idler arm diagram" to find it yourself.
Dec 18, 2010 | Dryers
I changed the belt on my Creda tumble dryer. Now its making noise
You may have to change the Guide wheel that the drum needs to rotate on
Sep 06, 2017 | Dryers
My creda reversair dryer no.37642 doesn't rotate, although there is heat in the drum. What could be wrong with it?
Most likely the drum belt is broken or the tensioner is broken this is not to expensive to fix and the belt can be bought at any applince store.
Mar 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Creda drier drum will not rotate when fully loaded
The belt could be worn or bad or the tension spring is to loose and not keeping enough tension on the belt. When loaded to max belt just slips and doesn't turn the drum.
Dec 16, 2009 | Sewing Machines
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
Dryer Drum not rotating
If warm air is still coming from the unit, but the drum is not rotating, it sounds like your drive motor is fine, but your drive belt is broken. Depending on you dryer model, these can be fairly easy to check, or may take a little creativity to get the dryer apart. Knowing your dryer model number would go a long way towards assisting further.
May 06, 2007 | Whirlpool LSW9750 Front Load Washer
Creda IWD12 Front Load Washer / Dryer Logo
93 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
