Question about Refrigerators
Need to unplug drain tube in 2005 roper fridge I have a Frigidaire frs26zgh. I have ice buildup in the bottom of the freezer too. I pulled everything out of the freezer including the shelves and the back panel. This exposed the cooling coils and the fan. I could see more ice and where the water was supposed to drain out the bottom to the drain pan. It was plugged. I tried to thaw it out to see if the ice was backed up in the tube, and am still waiting. When I pulled the fridge out and looked from the back I could see the pan the water was supposed to be draining in to and it was dry. How do you unplug the drain tube?
    President:
  • Refrigerators Master
  • 2,651 Answers
You can thaw it out by pouringboiling water down the drain trough, or use a hairdryer to assist you, ( i actually use the steam machine bought form the t.v.) afte clearing the ice, water will flow down the tube normally
Posted on Nov 09, 2008
Ice buildup on bottom of freezer
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Sep 01, 2014 | Kenmore Refrigerators
Water on bottom of freezer
Freezer is very cold fridge is 61 degrees
You could have a plugged drain tube under the evaporator coils(behind back freezer panel) which is causing the ice in the bottom of the freezer(when it defrosts). If it also is pluggged with ice to the air return from the refgigerator to the freezer side it will cause the problem you are having. Or you have two problems, plugged drain tube and evaporator fan not running or plugged drain tube and damper control iced up......
If you have a back-up unit, leave it unplugged for a day with the doors open to thaw out, may not help, good luck though, hope this helps
Jul 29, 2012 | Frigidaire DGHS2644KF (260 cu ft) Side by...
I have a Roper refgigerator RTATXKQ built Feb 2005. Ice buildup from the freezer is melting and dripping into the refrigerator compartment in the back where the air flows. I found a thin ice buildup and...
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½" in diameter this is the drain tube. Try using a turkey baster to flush out the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. After cleaning mix a 50 -50 solution of baking soda and water and run some down the drain tube this should help prevent future clogs. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Oct 11, 2010 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Every time my Frigidaire Model number frs26znh defrosts, water runs out of fridge door. of course, the pan in bottom of fridge is full of ice. water has not been connected for 6 weeks
Your Defrost drain Plug is clogged or kinked.
Check the tube from the freezer to the fridge, make sure it's connected, then pull out your drawers in the bottom of the fridge and clear your drain hole..
Mar 11, 2010 | Refrigerators
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Water leaking into fridge
Unless you have a lot of confidence in your ability as a handy person and plumber, it may be better to leave this to a pro. Here's the story.
When the freezer automatically defrosts, water from the melted ice collects into a tray behind the back panel of the freezer. There is a drain in this tray, and the drain empties into a pvc tube that carries the water down into an evaporation tray that extends from front to back on the bottom right side of the refrigerator. A fan blows air over the evaporation tray to dry the water in the tray before the next defrost cycle.
Over time, the drain tube gets partly clogged with gunk, the water in the upper collection tray doesn't drain completely into the lower tray, and when the defrost cycle ends, the water still in that upper tray freezes. After a few defrost cycles, enough ice forms in the collection tray so it blocks the drain completely, and this plug won't melt during the defrost cycle. Now every time there is a defrost cycle, water collects, overflows, and drips down through the air channel at the back of the fridge into the refrigerator section.
The fix is to clear the drain tube leading from the upper collection tray to the lower evaporation tray. Here's how (if you have the know-how to tackle the job):
First, move the fridge away from the wall, unplug it, and remove the fiberboard panel that runs across the the bottom back. From the front of the fridge pull out the trim grill that runs across the bottom. Locate the evaporator tray on the right, but don't remove it yet.
Empty the freezer, and be sure to safely store the removed items in another freezer, or an insulated cooler, if you can complete the job in an hour or two. Be careful with ice cream and such, which cannolt be allowd to defrost, even partially.
Remove the ice maker if you have one, remove the screws holding down the bottom panel of the freezer, remove it, and remove the screws holding the back panel, and remove it.
Leave the refrigerator door closed, to keep the food in it from spoiling. If this job is going to take you more than an hour or two, move the food in the fridge to another fridge.
Now you need to let the freezer defrost (a hair dryer will make it go faster, but don't let it get wet), and sponge out all the water, There will remain an ice plug in the drain at the bottom of the collection tray at the back. Use hot water to dissolve the ice plug, use a drinking straw inserted into the drain (don't let it drop!) to be sure the ice plug is melted.
You still have to clear the plastic drain tube of collected gunk. This is like snaking out a drain pipe. I found that 8 feet of 1/8 pvc tubing works well. Before you clear the drain tube, remove the lower evporation tray. There is a finger hole at the front. Use it to lift the tray up and forward (be carelful, it may contain water).
Put the pvc "snake" down into the drain in the upper collection tray, and gently work it down through the drain tube. You are done when the snake emerges from the bottom of the drain tube, at the back bottom of the fridge, above where the evaporator tray sits. . Snake up from the bottom, and then back down again from the top, to be sure the drain tube really is clear. Replace the evaporator tray, and slowly pour 2 cups of water into the collection tray at the top, and confirm that it drains quickly and completely into the lower tray.
Empty the lower tray, replace it, and reverse all the disassembly steps.
This is not a permanent fix, because the drain tube could clog again, but should be good for a few years before you have to repeat this operation. At least now you know the cause and the fix, and can deal more effectively with a repair tech, even if you don't tackle the job yourself.
Jun 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice buildup on freezer floor.auto defrost puts water on floor
You have a clogged drain. If you have a top mounted freezer you might have the drain line on the outside of the fridge. Look for a tube that is thicker than the water intake line and goes from back of bottom of freezer down into the back of the unit to a drain pan. Remove that tube and take it outside and use your hose to shoot a stream of water to clean it out.
If you have a side by side fridge, your drain is still at the lowest point at the rear of your freezer. You may have to removed the rear wall of the freezer to get at it. Remove the back cover to get at the other end of the drain tube. It needs to be cleaned out also.
Apr 22, 2009 | Refrigerators
Refrigerator side stops cooling
Drain stopped up.
Take out the bottom drawer in the freezer, look at the back wall and you should get a partial view of the bottom of the cooling coils. Directly below these coils is the drain area. You may need a light to see the drain hole. If this area is covered with ice then a hair dryer will help clear this so you can see the drain hole.
I have some O2 tubing that I put down the drain to clear any cloggs. Also, I seal the top of the drain hole around the O2 tubing with tape and use the air from my lungs to clear the drain tube. Pour a little water down this drain hole to make sure it’s clear.
Dec 17, 2008 | Frigidaire FRS26R4A Side by Side...
Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Dec 07, 2007 | Freezers
Refrigerators Logo
201 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
