This is first time for me with hydrostatic transmission dont know if it uses fluid if so what kind and where do you put it in?
SOURCE: need to know what kind of aouto matic drive fluid
Most units are sealed and do not require adding fluid. Normall 20w50 engine oil is used. Consult your owners manual or sears.com for confirmation.
SOURCE: need to find parts for riding mower hydrostatic transmission
yes it can be fix.but it might cost you alot of money.i will try to help you.let me know. want parts you need.i need a pic.i have lots parts.let me know.ok
SOURCE: Craftsman 15.5 hp 42
It takes 15w-50 or 20w-50 synthetic motor oil.Do not use hydrostatic fluid, it is too thin. Amsoil, Mobil-1, Purple Power or Lucas are four of the most popular brands. You have to suction it out from the plug on top of the transaxle and refill it there also to within 1.5 inch from the top,do not overfill,air is needed in top for expansion.
Testimonial: "hey please call my cell(828) 413-7222 need help now its worse"
SOURCE: checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
SOURCE: transmission fluid low, hydrostatic transmission
Quoted from your Owners Manual. . . . .
TRANSAXLE PUMP FLUID
The transaxle was sealed at the factory and fluid maintenance is not required for the life of the transaxle. Should the transaxle ever leak or require servicing, contact your nearest authorized service center/department.
