Question about Sharp R-1501 Microwave Oven
Sharp microwave R1050
Outside door cracked. Will I have to replace total door?
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Door Removal Sharp Microwave Model R-1611
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
Posted on Aug 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: crack in the door
You can order separate panels for the door as opposed to whole door, assuming they are still available.
We have the service / repair manuals for this model and have uploaded them to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on May 20, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-1480 replacment door handle
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and even part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
Posted on Jun 16, 2009
How can i replace the front door panel that has cracked at handle . it is whirlpool microwave over range
The parts are available from appliance parts houses. They do sell to the general public. I did one a few months ago. I think the outside door was around $30. It is not a difficult job. Just know that you have to take the entire door apart to do the job. 20-30 minutes.
Dec 10, 2014 | Whirlpool Microwave Ovens
The outside panel of my whirlpool model MH1160XSD0 model is crack can this be replaced?
Yes, the door panel comes off easy (3 screws on the side). Mine was cracked so I ordered a new one. Not the vent above it is cracked. Cheap plastic!
Mar 12, 2014 | Whirlpool MH1150XMQ Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Can I replace the front door panel kit myself?
No, it needs a special aligning for avoiding the microwaves leaking outside the oven.
If you replace it anyways, check with a microwave detector that there isn't any leak.
Oct 27, 2009 | Sharp R-1501 Microwave Oven
Crack in the door
May 17, 2009 | Sharp R-1405 / R-140 Microwave Oven
Door crack
Doors can be purchased, but they usually aren't cheap. Door panels can be purchased, but usually only the INNER panel. You can also get the door latches and handles. I don't know, however, if Sharp has any of the outer door components available without having to purchase a whole door. Refer to your owner's manual to see if there is a part listing index. If you can't find any part information, post back with your complete model number (located around the door opening) and I can see if I can find a part number for you. Hope this helps you.
Feb 07, 2008 | Sharp R-1500 Microwave Oven
Directions to remove and open door panel to repair safety door latch.
You don't have to remove door to remove panel. Panel is held in by an outer plastic retainer which can be removed by carefully prying with a small screwdriver. I can be replaced by pushing it back in place after repair is completed. If you cannot open door from the outside, remove cover and you can see latches. Pry up on latch which will let door open.
Jul 28, 2007 | Sharp R-1610 Microwave Oven
Sharp R-1501 Microwave Oven Logo
44 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
