Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Only 1 cam picture
I av a Dedicated Micros Digital Sprite 2 DSA DX09C 80GB,im tryin to canect 4 cameras to it,but up to now av only bin able to get a picture through VID 1. i carnt get 2-9 to work,can u help?
  • 1 more comment
  • shiresstevey Nov 09, 2008
    sorry but i av no manaul,and carnt find any thing on the on screen display to start them manauly
    i have conected two cameras on channel 1. they are bothr working fine, i then plugged one in one and anothe in channel 2 and then shut down for 10 mins for it to reset and they still are not working.
    no im un able to do any tests,iv just brought it second hand.
  • 103 Answers
The fact that you've just brought it second hand and that all the other solutions have not worked strongly suggests that your equipment has got a fault somewhere. Try contact your dealer.
Posted on Nov 09, 2008
  • 73 Answers
If none of these solutions work, yoru better off calling your manufacturer,
    Scholar:
  • 112 Answers
It seems that there is a major problem here. Other than just disconnecting the power and reseting it, I couldn't find many other solutions. My best suggestion is to actually contact the manufacturer and see what they have to say or see if you can get a manual that would help you better.
    President:
  • 1,952 Answers
Connect cameras to the video inputs marked VID1 to VID9 (9-way unit) or VID16
(16-way unit). Use the bottom row of connectors for looping through to other equipment
  • mohammed marika thambi
    mohammed marika thambi Nov 09, 2008
    Press the PIP key to toggle the main and PIP image.
    Press and hold the PIP key to edit the display, use to select the segment, press the
    required camera key to fill that segment.
    Press menu to exit.
    Quad
    Press the QUAD key to switch to quad display.
    Press and hold the QUAD key to edit the display, use to select the segment, press
    the required camera key to fill that segment.
    Press menu to exit.
    Multi-screen
    Press the multi-screen key to toggle between 9-way, 8+2, 12+1*, and 16-way* displays.
    Press and hold the Multiscreen key to edit the display, use
    to select the segment, press the required camera key to fill that segment.
    Press menu to exit. *16 channel version only.
    Sequencing cameras
    Sequence
    Press the sequence key to toggle the main monitor sequence on or off.
    Press and hold the sequence key to edit the full screen sequence.
    Use the camera keys to include or remove cameras from the sequence.
    Press menu to exit.
    Note: The spot monitor sequence can only be activated or edited in spot mode
    If the Digital Sprite 2 needs to be switched off for any reason, the shutdown
    procedure needs to be followed:
    1. Select ‘Enabled’ in the System Shutdown option.
    2. When the pop-up menu appears, press and hold camera 1 for five seconds to
    shutdown.
    3. The message ‘It is now safe to switch off your unit’ is displayed, switch the
    Digital Sprite 2 off at the wall.
    Warning: Data loss or disk failure may occur if a system shutdown is not
    performed before removing power
  • 905 Answers
You will need to plug a different camera in the one that is showing the video and confirm that the other cameras work , if they do work then the unit needs to be checked for the settings for viewing
if thats not the problem then the unit will need some testing to find out why it is not showing other camers
can you do some tests ?
  • 1 more comment
  • jason Nov 09, 2008
    then there is an internal problem that will need some testing to determine the fault in the unit
    can you perform these tests with a meter? do you still have a warranty?
    if you cannot do this kind of testing then use your warranty if you still have one or you will need to take it to an electronic repair shop to get the problem fixed
    will you need further assistance?
    this is an internal fault and it will need to be tested to determine the cause
    you can take it to your local electronic repair shop and have them fix it for you
    it needs some testing to be able to find the problem
    Sergeant:
    Champion:
  • 331 Answers
Here is the link to the manual  provided by "Ginko"
http://www.comlock.com/pics/DM-Digital%20Sprite%202%20DVR.pdf
And this has been written  about camera viewing
Camera Viewing
An option is available to view all cameras or selected cameras. All the cameras are
viewed by default. Cameras removed from viewing do not affect the cameras
being recorded.
To change the cameras to be viewed
• Press the ‘ ^ ’ cursor key to change the edit field to ‘Selected cameras’.
• A menu will display the cameras to be viewed.
• Press the camera key to toggle the camera in or out of the viewed sequence.
This camera will be displayed. A filled box denotes cameras that can be viewed.
Note: Cameras removed from view are not displayed on the main or spot monitor
in live or playback mode, multiscreen displays will show a blank segment.
hope this helps.
If it does not PLease post back
    Genius:
  • 1,913 Answers
Trym to connect with computer then let me know
  • 19,396 Answers
Youy need to install the drivers far all 4 cameras. Only one camera will be the default one, you need to start the other camersa manually.
I was given a Dedicated Micros sprite 2 without a power lead do i need one or can i connect to the computer as a power supply
would need more info as the system needs it's own psu.... are you meaning the power plug 3 pin type that fits into the psu or the 8 pin that fits to the system (would not try that with the 8pin)
3 pin is just standard kettle lead.
Jul 30, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Default installer password for digital sprite 2 ?
update for anybody that's looking for ages like i was . download the software from the home page and burn to cd. place in drive start machine and format all drives when asked to and you are good to go . Password has been removed... it takes a while so be patient ok
Sep 08, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
How to check the IP on Digital Sprite 2?
I have no idea what Digital Sprite 2 is , but one universal way to check an IP of a device is to put it after DHCP server and check that server's IP allocation table.
Most home routers have those DHCP servers built-in and functional, so maybe the real question here is "how to check the IP lease allocation table of my wireless router" :-)
May 25, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Feb 07, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
For got my pass word
As a reminder, the password is set using the camera select buttons. Depending on your model, there are only those limited selections to help you try and recall the password. Unfortunately, if you can not, D1 Sprite 2 systems must be returned to the manufacture to have the default password reset.
Jul 18, 2008 | Home Security
"fail" flashes on the screen for one camera
Sounds like a low signal voltage from the camera, should be 1v peak to peak, read with peak meter.
Apr 28, 2008 | Dedicated Micros Digital Sprite 2 RS Video...
Televison & Video Logo
78 people viewed this question
Top Dedicated Micros Televison & Video Experts
jason
electracon
 Russ Hill
Russ Hill
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
