Question about Intel Desktop Board D845EPIL Motherboard
Intel D845epi bios problem
Computer will not boot after a bios update failure. need bio file. where can i find it?
  • Intel Master
  • 3,606 Answers
5 Suggested Answers
SOURCE: BIOS-ROLLBACK UPDATE
first of all u always had to packup ur bios befor updating,however you can log to the web site and get an older version of the bios or u can copy that from any person who has the same M.B by using the update program it recommendes the packup acceptit and save the bios file on the hdd and stop the upgrade
take that file with u to ur pc and upgrade from it
Posted on Dec 13, 2007
map9966
  • 2351 Answers
SOURCE: bios update dont work
I'd like to know if this is the bios you downloaded?
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=1065&OSFullname=OS+Independent&lang=eng&strOSs=38
Posted on Mar 20, 2008
map9966
  • 2351 Answers
SOURCE: Updating BIOS
Hi aryo,
What I need to know is the name of the motherboard. The bios information is useless without the name of the motherboard & model number.
Posted on Apr 24, 2008
mysleuth
  • 152 Answers
SOURCE: Microcode Patch Error,Where to download Bios Free
What model compaq?
Have you tried HP.com ? If OEM they will have the driver. If not I use driverguide.com for drivers I can't find. mysleuth
http://search.hp.com/query.html?lang=en&search=++&qt=Intel+Solano+i815&la=en&cc=us&charset=utf-8
Posted on Apr 28, 2009
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
Failed BIOS update
CMOS battery.
hope this helps
Sep 11, 2012 | ASUS (P5RC-LA) Motherboard
Each time the computer boots, there's a note saying " intel CPU uCode loading error Press F1 to continue". what to do to fix this error?
it seems you will need update your bios
All BIOS update files for Intel® Desktop Boards are available on Intel
May 09, 2011 | Intel Computers & Internet
I need data or file eeprom for bios Intel D845EPI ?, I have programmer IC. Please...
You can find the BIOS files here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=10506&keyword=bios+Intel+D845EPI&lang=eng
Feb 27, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
Problem loading into windows 7 after updating bios
FIRST - you didn't use the bios update from ASUS?
Second - USE CORRECT HEADER FOR QUESTION
Third - This is an
Intel® Desktop Board DG31PRCorrect?
Found Different BIOS file than one you used.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2839&DwnldID=18881&lang=eng
ALSO = List of ALL BIOS Updates (quite a few)
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
BIOS you used is two years old - on page 2
Try a newer version
Apr 04, 2010 | ASUS P5LD2-VM Motherboard
I want to the bios intel motherboard d845PEBT2 place sent me
First be clear, do you want to update your BIOS & if so then go through this first: To identify your current BIOS version, check the BIOS version string:
  1. During boot, enter the BIOS setup by pressing F2.
  2. Check the Main menu.
  3. The 4-digit number after the '86A' or '86I' is the current BIOS version, as in this example: MQ96510H.86A.1663.2007.0319.1957
  4. Press Escape to exit BIOS Setup.
Important:
  • Update the BIOS on your computer only if the newer BIOS version specifically solves a problem you have. We do not recommend BIOS updates for computers that do not need it. You can view all new BIOS fixes in the Release Notes included on the BIOS download page in Download Center.
  • Before initiating a BIOS update, be sure to read and precisely follow the update instructions. You may wish to print the instructions for easy reference.
  • If a BIOS update process is interrupted, your computer may not function properly. We recommend the process be done in an environment with a steady power supply (preferably with UPS).
  • All images in the examples used in the instructions are specific to certain desktop boards and are for illustration purposes only. You need to select the correct BIOS files for your desktop board.
There are up to six methods of updating an Intel® Desktop Board BIOS to the latest version. The number of options made available for any particular board may vary, depending on drive support and BIOS update file size. You only need to use one.
All BIOS update files for Intel® Desktop Boards are available on Intel(link: http://mysearch.intel.com/corporate/default.aspx?culture=en_US&q=d845PEBT2&category=all&adv=0&value=0&searchsubmit.x=30&searchsubmit.y=12).
If simply want to clear the BIOS then either remove the small battery on the MB, wait for a couple of minutes and replace it. Else close to the BIOS chip look for a 3 pin setup on the mother boar with a jumper on two pins Remove the jumper, wait for 10-20 seconds & replace it. That will clear the BIOS.
A word of caution, do not update the BIOS if your PC is working properly. Do it when prompted to,during installing a new software or hardware this message will pop up on the screen.................sodeep
May 15, 2009 | Intel Desktop Board D845PEBT2 Motherboard
D845epi Is frozen on Express BIOS Update
hold down the power buttom till the system turn off and wait for some minutes then power back on. this situations happens when you are updating an old bios.
Feb 18, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Updating BIOS
Different computers different files
You need two files to do the Job read instructions carefully
1 is for bios the other is the program that install it
Aug 30, 2008 | Intel Motherboard
Problem with intel d845gvsr display driver
download the driver from these websites and uninstall the old1 and try installing new 1..
bios-and-system-update.free-driver-download.com/Intel/19970/Intel-D845EPI-D845GLVA-D845GVSR-Express-BIOS
www.opendrivers.com/driver/230315/intel-d845glva-d845epi-d845gvsr-express-bios-va84510a.86a.0052.p19-free
www.nodevice.com/driver/company/INTEL.html
www.techtree.com/.../jsp/list.jsp?list=asktt_allcomments_list_notsignedin&q=1&answer=N&cat_id=41
if the same problem persists then there may be problem with operating system just reinstall it...
may be due virus attack some system files have became unstable so try reinstalling os...
and also after reinstalling just install some good antivirus............
Feb 10, 2008 | Intel D845GVSR Motherboard
Intel Desktop Board D845EPIL Motherboard Logo
201 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
