Question about Lowrance Globalmap 5200c Color Chartplotter
LOWRANCE 5200c nEW UNIT..DOES NOT PICK UP SATTELLITE..STAYS IN SIMULATION MODE. EXTERNAL ANTENNA..PLEASE HELP
  • gwoodams May 09, 2009
    the 5200c will stays in simulation mode.
I need help to mine does the same thing
Posted on Feb 03, 2010
My global map 5200c curser is blinking a question mark
That question mark means the GPS antenna cannot get a satellite fix for the GPS to triangulate your position.
Be sure there is no aluminum above your antenna. This will block the gps signal. Also be sure your GPS antenna is at least 24" or more away from any other electronics The electromagnetic field electronics emit will disrupt the GPS signal coming to your antenna.
Sep 09, 2014 | Lowrance Globalmap 5200c Color...
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Error message
Check the connections pull and replace, also check the base cord of the antenna.
Sep 22, 2009 | Lowrance Globalmap 5200c Color...
Can't get out off demo mode - trying to use my chart - navionics gold 20XG but it shows only demo mode. can't find instructions in the manuel or cannot understand them. (part off my problem is that my...
Try this hard reset procedure: (warning: this procedure will erase all waypoints that have been saved)
1. Turn unit off
2. Press and hold the ZIN, ZOUT, and PWR keys at the same time.
3. Release the ZIN, ZOUT, and PWR keys once the alarm "warning, do not rely..." appears.
The unit should now be out of demo mode.
Jul 13, 2009 | Lowrance GlobalMap 5200C GPS Receiver
Gps wont pick up satilites
Make sure all the connections at the back of the unit are tight. If it still doesn't respond try a new puck.
Apr 15, 2009 | Lowrance Globalmap 5300c Igps 5" Screen...
Global map 5200c loading problems- navionics platinum hot maps
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out and it works every time.
Mar 22, 2009 | Lowrance Globalmap 5200c Color...
Lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Mar 08, 2009 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance Globalmap 5200c Color Chartplotter Logo
227 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
