Question about Sony WEGA KLV-26HG2 26 in. HD-Ready LCD Television
Accident Damage - chances repairable or not?
Hi Friends, My TV was knocked off its perch yesterday. All I get now when I turn on is a fist sized shatter on the screen and jagged lines going everywhere and no picture whatsoever. Is it likely that this can be repaired or should I cut my losses and buy a new one? Many thanks for your advice. Chris
    President:
  • 3,130 Answers
OH NO!~!!! It sounds like you broke the display panel. You may be able to replace it or have it replaced but most likly it will cost more then it is worth. Inside on one of the edges is a number. Get it and look up LCD displays on the net as there are only a few major supplyers of LCD panels, and I had a freind get on for 1/3 the price that sony was asking for, and everything plugs into the display or has ribbon cables and need no alighnment after works. Good Luck PS please dont forget to rate this thread.
Posted on Oct 23, 2006
SOURCE:
Yesterday the wind blew the door open on volvo c70. damage was done. What are repair estimates?
Without extensive photo's it's impossible to even guess.
Assuming the car is driveable, Google your local bodywork repair shops & drive around to some of them to show them the damage. They will be able to assess the damage on the spot & give you an estimate on the spot or subsequently, by e-mail or in writing.
If you can get recommendations from friends about repair shops, then so much the better.
Best of luck.
Mar 08, 2018 | Volvo Cars & Trucks
I have been hearing mixed reviews about sandpaper bird perches. Are they good or bad for birds?
From what I have learned, sandpaper perches can damage your bird's feet, causing a condition known as "bumblefoot". They tend to be too abrasive. I would recommend buying a cement perch instead.
Aug 30, 2012 | Allied Precision Birds
What is a grooming perch?
This is a type of perch for your bird cage that allows for some self-grooming. It is a great way to trim down your bird's nails. They often come in great space-saving styles such as corner perches and half sizes. Look into concrete-blended perches. In my opinion they are the best type of grooming perches. Here are a few examples -
http://www.perchfactory.com/bird_cage_perches/sandy_cement_perches.htm
http://www.avianenrichment.com/store/pc/Grooming-Perches-c133.htm
How important is perch diameter?
Perch diameter is an extremely important factor in relation to perch choice. It is crucial that you choose a perch that is the right size for your bird. Here is a sizing chart I came across to help educate you further on perch diameter. Your bird's foot should wrap around approximately 2/3 of the perch; their toes should never meet/overlap.
Bird size Perch Diameter
Extra small 1/2 an inch or less
Small 1/2 an inch to 5/8 of an inch
Medium 3/4 of an inch to 1 inch
Large 1 inch to 1 1/2 inches
Extra Large 2 inches to 2 1/2 inches
Does perch size matter?
Yes. It is a good idea to get your bird a variety of perch sizes. Smaller perches allow for a better grip resulting in increased exercise, while larger perches will help trim your bird's nails and beaks.
Ps3 red light
Several this can cause this error. Its a fail safe so there isn;t further damage to the ps3.
Some reasons for this error:Over Heating (80% of the time)Damage to GPU or CPU (98% Chance of the Happening)Dust (90% Chancebad PSU (25 % Chance of this happening)low voltage (20%Faulty Fan (30%)Water Damage (3%)Bad caps (5% Chance)1% others
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
Feb 24, 2012 | Video Game Consoles & Games
Have had to replace lamp twice in the last two years on my Sony KDS-R60XBR1 HDTV. Yesterday I ended up with the four blinking red lights showing on the Power/Standby indicator nothing by the lamp...
hi,
fist of all try to reset ur tv. to reset do the following.
Turn on the TV. While holding down the up arrow button on the remote control, press the POWER (on off switch) button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
Dec 31, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Car overheated and knocking.changed rod bairings.good to go. now
99.999% of all spun bearings cannot be replaced with any expectation that the problem will be repaired 1. debris from the old bearing enters the oil port on the crank and will damage the new bearing as well as others. 2. damage to the crank itself must be precisely machined to exact size and concentricity. Most crank pins are too thin and will become egg-shaped after machining and re-use.3. even replacing the crankshaft without flushing the entire oil system is a gamble. Waste no more time or $ on this and either get another engine or different vehicle.
Jun 08, 2009 | 1991 Toyota Cressida
Sony WEGA KLV-26HG2 26 in. HD-Ready LCD Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
