Question about Mitsubishi WS-55809 55" Rear Projection Television
Tv clicks on then clicks off right away, nothing even shows up on the screen.
When I push the on button the makes the sound like it's starting up, then immeadiatly makes the sound again and is turing off. That's all the farther I get.
Thanks
Mike
  • 85 Answers
Find your reset button also,there're 2 fuses inside
Posted on Nov 14, 2008
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
I am not able to control the recording level on lower right screen. When I click on it nothing happens.
Maybe your laptop has buttons that control the level also, if so press them.
Most laptops have keystrokes that control the volume level. Normally you will have to Press and Hold the FN function key at the lower right portion of your screen and the corresponding key that takes the volume up. Normally the correct key will show the icon of a megaphone with the )))) volume signal.
More importantly make sure you have the Recording checked in the Audio Sound Properties.
Apr 21, 2012 | Apple MacBook Pro Laptop Computer with...
2000 SC92 TURN KEY ON PUSH START BUTTON,NOTHING. SHOWS MILAGE TO CHECK ENGINE AND GREEN NEUTRAL GOES AWAY. PUT NEW BATTERY IN READS 12.5 VOLTS. ALL LIGHTS SHOW ON,BATTERY GOOD.
sounds like you have a bad connection on you're battery or on a ground wire some where on make sure the ground wire on the motor is tight
May 11, 2011 | 2001 Victory V92 Cruiser
I get a black square in the middle of the tv. I can still see part of the program and hear it but there is a code or something that pops up it starts with lid and has numbers following. If I push the input...
U have the tv original remote wright?Yes.Used ur tv remote look for a button that said CC.Pushes a few times make sure all like CC1,2,3 so on to all off.The black square box show up in the middle of the tv screen,numbers and printting words on the screen it is are call Close Caption for the hearing impair person to read,will disappear from the middle of the tv screen.
Apr 04, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
I push the on button the red light comes on, tv makes clicking sound, screen does nothing. TV has no static. I checked fuses. what should i do next?
If it is a CRT type tv. Could be the start up circuit is failing. Check it using remote to turn on the tv. If nothing happens check the fuse if ok, then you may have start up problem or, faulty high voltage section. But clicking sounds may indicate you have standbye voltage.
If you can isolate the B+ supply you can check the specified voltage if whether in spec. Then if ok then Horizontal output transistor or the flyback or other minor component like diode and the capacitor.
If you are not inclined on electronics better not mess with it. It will bite. Have a repairer check that.
Oct 07, 2009 | Toshiba Televison & Video
Black box in middle of tv screen
This is a background for text, even though you aren't seeing any text at the time. Since it covers most of the screen, it sounds more like a demo mode screen than closed captioning. Go into your setup menu and make sure that neither of those is selected. If necessary, restore the factory settings. I'm assuming that this is coming from the tv itself, and that you don't have a VCR, Tivo, etc. Good luck!
Jun 15, 2009 | Hitachi 50UX57B 50" Rear Projection...
Tv doesn't turn on.
Does this have a replacable lamp? If so it will do exactly this. If it does it's probably fried.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
VCR shows "PLAY" on machine but doesn't show on TV
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | GE VG4054 VCR
Mitsubishi WS-55809 55" Rear Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
